Why is f(u)e^(iω(t-u)) not L¹(ℝ×ℝ)?
6 replies · 4K views · last reply
laurabon
Hi everyone in the following expression
##f(t)=\frac{1}{2 \pi} \int\left(\int f(u) e^{-i \omega u} d u\right) e^{i \omega t} d \omega ##
the book says I can't swap integrals bacause the function
##f(u) e^{i \omega(t-u)}## is not ## L^1(\mathbb{R} \times \mathbb{R})##
why ? complex exponential is not always bounded?
FactChecker said:
What properties does ##f(u)## have?
it is Fuorier inverse theorem with ##f## in ##L^1(\mathbb{R})##
Note that ##\sin## and ##\cos## are not integrable over ##\mathbb R##.
I came up with this . Is correct? ##
\begin{aligned}
& \left|f(u) e^{i \omega(t-u)}\right|=|f(u)| \\
& \iint|f(u)|=\int_{-\infty}^{\infty} c = \infty
\end{aligned}##
how should I use the fact that sin and cosine are not integrable ?I mean to verify that is in L1 I always have to use the fact that ##|e^{i \omega(t-u)}|=1## I think
\begin{aligned}
\end{aligned}##
I don't think that works. First, let's take ##t = 0##, where the integral reduces to:
$$f(0) = \int_{-\infty}^{+\infty} \bigg ( \int_{-\infty}^{+\infty}f(u)e^{-iwu}\ du \bigg ) \ dw$$If we try to swap the integrals and look at:$$\int_{-\infty}^{+\infty} f(u) \bigg ( \int_{-\infty}^{+\infty}e^{-iwu}\ dw \bigg ) \ du$$We can see immediately that the inner integral does not converge and does not represent a well-defined function of ##u##. Because neither ##\cos(wu)## nor ##\sin(wu)## is integrable with respect to ##w## on all of ##\mathbb R##.
Notice f(x)==1 is also bounded. To be able to be in ##L^1(X)## , where ##X## itself is unbounded, your f has to decrease fast-enough.
