Why is less force needed to pull a block at an angle compared to pushing it?
  • Thread starter Thread starter DrummingAtom
    Angle Difference
2 replies · 2K views
DrummingAtom
A block rests on a level floor. To move it at a constant velocity, why do you exert less force if you pull it at an angle above the horizontal than if you push it at the same angle below the horizontal?
I know that pushing at an angle below the horizontal is going to add to the weight (w) of the block. I've come up with these expressions:
1) Fpull = w*sin(θ)
2) Fpush = w/sin(θ)
Since w in 1) is going to be multiplied by a number less than 1 it's going to decrease the magnitude of F. And since w in 2) is going to be divided by a number less than 1 it's going to increase the magnitude of F.
Is this the best way to express this relationship? Thanks for any help.
It's better to consider kinetic friction and the sum of vertical forces. The expressions you wrote down are incorrect. The applied force is independent of the weight. You need to draw a force diagram and examine the sums of forces.
