Why is My C++ Program for the Bateman Equation Returning NAN?
  • Topic: C/C++
  • Thread starter Thread starter lapo3399
    C++
5 replies · 9K views · last reply
lapo3399
Hello,
I am attempting to create a program that will evaluate the Bateman equation for radiactive decay series, given several decay constants stored in a text file. I am not sure where this is going wrong, but no matter what chain member I enter in as the desired nuclide to find the mass remaining after 1 million years, it outputs NAN - even when I choose the nuclide that I am certain to have a perceivable value. The equation I am emulating later in the program is shown below, please help to explain why this is not working! All help is appreciated!
http://img515.imageshack.us/img515/5097/screenshotml6.jpg
Code:
#include <iostream>
#include <math.h>
#include <fstream>
#include <string>
using namespace std;
int main(int argc, char** argv)
	string line; //for file input
	int iter; //stores which nuclide will be calculated for
	double dcs[23]; //array for decay constants
	int anum = 1; //counting var
	ifstream deconst;
	deconst.open ("decayconstants.txt", ios::in); //file with decay constants
	if (deconst.is_open())
		while (! deconst.eof())
			getline(deconst, line);
			dcs[anum]=strtod(line.c_str(), NULL); //store as double in decay constant array
			anum++;
	std::cout << "What nuclide in the chain should be evaluated?";
	std::cin >> iter;
        //I separated the equation into multiple parts
	double consts=1; //part one: the multiplied decay constants at the beginning of the equation
	double init = 100; //the intial mass, N(O)
	double time = 1000000; //the variable t, one million years
	double sum=0; // the second half of the equation, the summation
	double totalmass; //the product of consts,init, and sum
	for (int i = 1; i < iter; i++)
		consts=consts*dcs[i]; //multiply all the necessary decay constants
	for (int q = 1; q < iter; q++) //the summation
		double expo = exp(-dcs[q]*time); //determine the numerator in the summation
		double denom = 1;
		for (int w = 1; w < iter; w++) //the product
			if (w==iter) //k can't be j
				break;
			else
				denom = denom * (dcs[w]-dcs[q]); //multiply together to get the product
		sum = sum + (expo/denom); //add up all of the summations
	totalmass = sum*consts*init;
	std::cout << totalmass;
	return 0;
Thanks again!
Well, I can't run your program without the file it needs to read, but I'd suggest putting some count statements throughout the code to print out the intermediate values.
- Warren
I've attempted that, and I finally realized what the problems where this morning. Firstly, the first for loop should read "i<(iter-1)", and I shouldn't have included the break statement in the other for loop.
Hi,
I see that you said your program worked. I am working with a few students to develope a detector but i also needed them to study the decan chains of Radon. I think your program will be useful, do you think i could get a copy of it?
have you checked all of the values prior to use?
If so, are you trying to calculate a null with an int/double?
Hi,
would it be possible to get a copy of the source code?
