Why is my pressure regulator drifting down?
The discussion focuses on a self-venting single-stage pressure-reducing regulator that reduces pressure from ~2500 psig to ~1500 psig, experiencing a steady decline in downstream pressure at ~50 psi/hour after three hours of stability. The issue may stem from thermal contraction due to cold gas affecting the regulator or a potential fault with the downstream gauge or transducer. Condensate accumulation is considered but deemed unlikely to cause the observed pressure drop. Testing the gauge is recommended to rule out gauge-related faults.
  • Understanding of pressure-reducing regulators
  • Familiarity with pressure transducers and their operation
  • Knowledge of gaseous nitrogen (GN2) properties
  • Basic principles of thermal dynamics in gas systems
  • Investigate the effects of thermal contraction on pressure regulators
  • Learn about troubleshooting pressure transducers and gauges
  • Research methods for preventing condensate accumulation in gas systems
  • Explore the impact of ambient conditions on pressure regulation
Engineers, technicians, and maintenance personnel working with pressure regulation systems, particularly those dealing with gaseous nitrogen applications and pressure measurement instruments.
steves1080
I have a self-venting single-stage pressure-reducing regulator that takes ~2500 psig and steps it down to ~1500 psig (here is a link with the specific details of the hardware if interested: http://www.items.se/Dokument/44-1300_10061107.PDF). I experienced some odd behavior recently where the pressure transducer in the downstream process piping began a steady decline at ~50 psi/hour after remaining stable for ~3 hours. This pressure should be stable since the GN2 sitting in this line should be static (nothing is actually flowing during this time). I cannot seem to explain why this is occurring. Upstream of the regulator, pressure is being supplied to multiple other locations where it does continuously flow. Any insight as to what is occurring would be greatly appreciated.
Thanks
A fellow coworker seems to think that condensate is accumulating and causing the vent port to become clogged, but that would only sort of make sense to me if the outlet pressure was rising. This reg is located in an enclosed panel in an outdoor environment. It is not uncommon for there to be condensation on the pipes in this panel.
It's air or steam or what?
It's GN2
steves1080 said:
It's GN2
Gaseous Nitrogen I presume.
Correct
I would check your gas is warm before getting to the regulator. It might be thermal contraction as the gas cools the regulator - or cold gas upstream is cooling the regulator via the pipes.
Wouldn't worry about water (ice) inside as nitrogen gas contains very little of it.
How do you know that it is not a fault with the downstream gauge or transducer ?
I have seen that sort of thing happen when a gauge leaks and builds up pressure on the back of the gauge.
Can you exchange test the gauge ?
27K
  • · Replies 22 ·
9K
