Why Is My Valve Exhaust Port Calculation Different?
The discussion revolves around the calculation of valve exhaust port flow rates in a pneumatic system, specifically addressing discrepancies in values derived from an article. Participants explore the equations and parameters involved in these calculations, including pressure, temperature, and flow rates, while seeking clarification on the correct application of these variables.
  • One participant questions the value of P1 used in the calculations, suggesting it should be derived from P2 and a given pressure difference.
  • Another participant points out a potential typo in the original post regarding the calculated flow rate, correcting it from 1.833 cfm to 1.185 cfm.
  • There is a discussion about the correct interpretation of temperature units, with a suggestion to convert Fahrenheit to Rankine instead of Kelvin.
  • One participant proposes that the flow rate used in a subsequent calculation may have been misidentified, suggesting it should be 9.94 scfm instead of 11.75 scfm.
  • Concerns are raised about unit conversions, particularly regarding the pressure units and how they interact with other variables in the equations.
  • Another participant clarifies the meaning of the variable g in the context of the equations, indicating it refers to acceleration due to gravity.
  • There is a discussion about the correct method for calculating delay time, with participants attempting to reconcile their results with those presented in the article.
  • One participant expresses confusion over the inclusion of a factor of 60 in their calculations, seeking clarification on how it affects the final time delay result.
Participants do not reach a consensus on several points, including the correct values for pressure and flow rates, as well as the appropriate units for calculations. Multiple competing views remain regarding the interpretation of the equations and the parameters involved.
Limitations include potential typos in the original article, unclear definitions of symbols and units, and unresolved mathematical steps in the calculations presented by participants.
Individuals working with pneumatic systems, engineers involved in flow calculations, and students studying fluid dynamics may find this discussion beneficial.
arokisbobcat
Hi,
I am following this particular article from machinedesign.com about properly sizing a pneumatic system - http://machinedesign.com/archive/right-sizing-pneumatic-motion-systems
In the section Valve Exhaust Port, he does a calculation for the valve loss coefficient and arrives at 1.833 cfm. I have tried to follow his numbers but am not coming up with the same value. I am reaching out to the board to see if you can help me understand where the author came up with this value.
I used the equation he specified in the beginning -
Q = 22.48*Cv (((P1-P2)*P1)/(T*G))^1/2
and used the following values
Q = 9.94 cfm
P1 = 79.7 psi
P2 = 14.7 psi
T = 273 + 70 = 343
G = 1 (SG of Air)
Please let me know where I am going wrong in this equation.
Thanks
How did you come up with the P1 = 79.7 value?
In the article he states that P2 = 14.7 and ΔP = 5 psi so then P1 = 14.7 + 5 = 19.7 psi
Additionally, I did not see any temperature given but 70°F is a STP value so that is OK; but, Fahrenheit should be converted to Rankin not Kelvin so T = 70 + 459.67 = 529.67°R
I have done the calculation but I think these changes will get you the answer you are looking for.
JBA,
Thanks for responding. I took your values came up with the value the author cites in the article - 1.185.
**Please note to anyone reading this threat that I made a typo in my original post - 1.833 cfm should be 1.185 cfm.**
9.94 = 22.48 * (Cv) * (((19.7-14.7)*14.7)/(530*1))^1/2
Cv = 1.187 (close to 1.185 as stated in article)
Thanks for the clarification with the values.
I have a follow-up question. In the delay time section, the author cites the following equation:
Td = (Pe*g*Ve*ks)/(Qm * Vs^2)
where Td = time delay (seconds)
Pe = change in pressure (79.7 - 34.91 psi)
g = .075 lb/ft^3
Ve = exhaust volume - 5.07 in^3
ks = 1.4 for air
qm = flow rate - this I'm not sure what value he's using
vs = 1127 fps, volume of sound
Please let me know if someone can explain how the author is calculating .054 sec from this equation. I can't seem to identify what value I am misinterpreting.
Thanks,
From the use of Q=11.75 scfm in the four calculations just above this one it might be assumed that he is using that value for q in this calculation. The symbol change from Q to q may be just a careless mistake when copying the equation into the article but we don't know if that is true. I suggest that you try using that value for this calculation in see if the resulting answer matches his.Just as quick note for your general information on units. The correct designation for vs is "velocity of sound"
Hi JBA,
I used 11.75 as my Qm value but did not receive the correct answer. I thought, perhaps, my units were incorrect so I converted all inch measurements to feet and all minutes to seconds. I don't see how the pounds value, from value Pe, which is either PSI or PSF cancels out. All the other values are either a volume or a velocity and don't have an expression of pounds to offset the Pe value. Please let me know what I am missing.
Thank you for all of your input thus far. You have been a wonderful help!
I have finally worked through the units issue and sorted out what the units are for qm and how the equation can end up with sec as it finished units. See the next post for all of the details because I cannot paste everything I need using the editing function on this earlier post.
First your value for g is an error g is the symbol for the acceleration of gravity = 386.4 ips2 (inches / sec^2 ) as he uses it in the Physics Section:
"Assuming a linear ramp (constant acceleration), peak velocity is twice this or 62.5 ips. Divide by time again to get acceleration, 651 ips2 or 1.685 g (651 ips2/386.4 ips2 = 1.685 g). Thus, the required force is 1.685 X 10 lb (due to acceleration) + 10 lb (due to gravity) = 26.85-lb force. If there are other forces, such as guide friction, they would be added here."
Also I was in error in selecting the 11.75 scfm value for this calculation I now think it should be 9.94 scfm as per the following:
"Multiply by 79.7/14.7 to convert to standard conditions, 9.94-scfm exhaust. In the same manner, calculate the supply flow during motion (without the rod) and get 11.74-scfm supply. These exhaust and supply flows will be used to estimate all other component pressure drops in the circuit."
Next, the units for qm are Q in scfm (ft^3/min) converted to qm in "lbs/sec" in the manner that the author used in the original Delay Time: Section as follows:
"Calculate delay time, td, as follows:
td = ΔPegVeks/qmvs2. Here, ΔPe = 79.70 - 34.91 psia (the piston low side pressure). Density of air is approximately 0.075 lb/ft3 at 528°R. Velocity of sound vs is approximately 1,127 fps at 528°R. Ratio of specific heats ks for air = 1.4."
With that sorted out this is how the units reduction works out:
and then (with the unit cancellations shown by matching colors)
I think if you do these conversions and use the new g and Q = 9.94 scfm you will have a good chance of getting the stated time answer.
Don't feel bad if you didn't find all of this. As I stated earlier, the author did not make it easy and really the only way I found the right path to "qm" is that I worked with gas flow problems for last 20 years of my career and mass flow in lbs/sec is common in these types of calculations; so, when I discovered I needed a "lb" for my units conversion I went looking for the possibility that he had used mass flow rather than volume flow in his calculations, and, finally found it.
JBA,
Thanks for your help with this. I was able to calculate the correct answer and follow your method, with the exception of the 60 sec in the 1/qm value. When we calculate qm, we obtain a value of .0124 lbs/sec. If I multiply this by 60 sec, I get .7455. Taking the inverse of this for my final Td equation results in the correct value of Td per the article. But if I multiplied this value by 60 sec., wouldn't I only have lbs as my qm value. Then I wouldn't have any value in seconds for my final Td answer.
So for my Td equation, I have the following:
Td = Pe * g * Ve * k * (1/qm) * (1/vs^2)
Td = 44.9 psi * 1.6885 g * 5.07 in^3 * 1.4 * (1/.7455 lbs) * (1/13524 s^2/in^2)
Td = .053 seconds
I followed your method and put this into excel just as you have and it helped me arrive at the answer (attachment). I'm just a little confused though on the 60 sec calculation and how the seconds still remains for the final Td (time delay) value.
I included the 60 in the seconds conversion was because the original Q was in cfm cubic feet / minute and I was converting it to cubic feet / second in my final conversions. You included a minutes to seconds conversion in your Q conversion before entering it into your final qm equation; and, this resulted in the 60 seconds per minute conversion being duplicated in the calculation. So, your confusion was basically my fault by sticking the 60 value in my otherwise strictly units conversion equation.
Edit: One main problem with the article is that the author was not careful to define all of his symbol units; but, this is not unusual even in published technical books (in that case, often the units are explained once in some paragraph in chapter 2 and you are expected to remember that when trying some example problem in chapter 10) and it really drove me crazy when it happened in my engineering course textbooks.
JBA,
That makes sense now. Thanks for all your help with this! I believe this could be really beneficial for me to apply at work.
I commend you for your determination and persistence in working your way through this learning process. Just assisting with the two issues you requested caused me cringe at the thought of going through all of the calculations in the lesson.
37K
  • · Replies 29 ·
10K
