Why is standard deviation biased compared to variance?
42 replies · 11K views · last reply
Agent Smith
TL;DR
What are the uses of variance and standard deviation and how do they differ?
Going through my notes ... and I see the following:
1. Variance = ##\displaystyle \text{Var(X)} = \sigma^2 = \frac{1}{n - 1} \sum_i = 1 ^n \left(x_i - \overline x \right)^2##
2. Standard Deviation = ##\sigma = \sqrt {Var(X)} = \sqrt {\sigma^2}##
Both variance and standard deviation are measures of dispersion (colloquially the spread in the data). Higher their values, more spread out the data is.
Statement B: The square root function is not linear and so standard deviation is biased when compared to variance.
Questions:
1. Do high variance and standard deviation mean greater variability in the data?
2. What does statement B mean?
The answer to 1 is "Yes".
The answer to 2 is "nothing". It is a meaningless statement because the concept of 'bias' only applies to estimators. A correct statement would be "The standard deviation of a sample from a population is a downwards-biased estimator of the standard deviation of the population from which the sample is taken". For more detail see https://en.wikipedia.org/wiki/Standard_deviation#Uncorrected_sample_standard_deviation.
That is true if the sum is divided by n, but the OP has divided by n-1, giving an unbiased estimator.
@andrewkirk , by downward bias, do you mean it underestimates the variability in the data?
@FactChecker I didn't know dividing by ##n - 1## instead of ##n## corrects the bias. Gracias.
Statistics is hard! And I'm merely scratching the surface.
Can someone tell me what "square root function is not linear" means? I know that, if ##\text{Var(X)} = 100## and ##\text{Var(Y)} = 81## that ##100 - 81 = 9## but that ##\sqrt {100} - \sqrt {81} = 10 - 9 = 1## A ##9## point difference in variance looks like becomes only a ##1## point difference in standard deviation.
The graph is not a straight line.
Graph of f(x) = x^0.5 on a grid with x-axis from 0 to 9 and y-axis from -3 to 4, showing a curve rising from the origin and flattening as x increases.
That is not a good way to judge if a function is linear. Consider the function, ##y=100 x##. It is linear, but a 1 unit change in ##x## becomes a 100 unit change in ##y##.
Agent Smith said:
TL;DR Summary: What are the uses of variance and standard deviation and how do they differ?
The big difference between variance and standard deviation is that the standard deviation has the same units as the mean.
I'd say that they measure the same thing. The advantage of variance is that the variances of independent random variables add meaningfully while their standard deviations don't.
@FactChecker , gracias for the graph, it makes it clearer. I was trying to show how a given difference in variance becomes a much smaller difference between the corresponding standard deviations.
:thumbup:
This is true of the variance, but not of the standard deviation. Sample standard deviation is always a biased estimator of population standard deviation.
groan. Actually very nicely done. groan.
I stand corrected. Thanks. I learned something I have had wrong all my life. The relevant part of this backs up what you said.
:thumbup:
This is not correct. If the variance is less than one then the standard deviation is larger than the variance. And this depends entirely on what units one is using.
Point! But can the variance ever be < 1? I know variance can be 0 e.g. for the data set 4, 4, 4, 4, 4.
Say we take this data set: 4, 4, 4, 5.
The mean = 4.25
The variance = ##\displaystyle \frac{1}{n} \sum_{i = 1} ^4 \left(x_i - 4.25 \right)^2 = 0.203125##
The standard deviation = ##\sqrt {0.203125} \approx 0.451##
##\sigma > \sigma^2##
Is the variance contradicting the standard deviation?
The mean = 4.25
What do you mean by variance contradicting the standard deviation?
Re linearity, I suspect both biasedness as well as maximum likelihood estimators may only be preserved by linear transformations. Maybe @statdad can confirm or deny this?
Well, ##\text{Standard Deviation } \sigma > \text{Variance } \sigma^2##
The standard deviation suggests there's high variation while the variance suggests there's low variation. The same problem arises when ##\sigma^2 > 1##.
WWGD said:
No, expectation itself is linear. E[2X]=2E[X].
##f(X) = 2X##? The other function/operation must be linear?
What I mean is that if X is a random variable, then the expectation of the RV 2X is twice the expectation of X.
@WWGD ☝️
Agent Smith said:
Well, you can argue too, that when Variance increases, so does SD, by their functional dependence, at least when variance >1. But what notion, messure other than those two, do you use as a measure of variability? But I was wrong above. There are nonlinear transformations that preserve unbiasedness, maximum likelihood property.
@WWGD it seems I unable to read statistical results. What does a standard deviation ##\sigma = 2## mean? Assuming a normal distribution, and a mean, ##\mu = 35##, I can infer that ##95\%## of the data lie in the range ##35 \pm 2(2)##. Is that how we interpret standard deviation?
That's close, yes.
The mean = 4.25
Say your data set is 4, 4, 4, 5 is in liters.
This is exactly the same as 4000, 4000, 4000, 5000 milliliters. Calculate again and you get a larger variance, which is greater than the standard deviation. As you can see, comparing the magnitudes of the two isn't meaningful.
The units are different, so it makes no sense to compare the size of variance and standard deviation. It does make sense to compare the size of the mean and the standard deviation, they are the same units.
There are two numbers. One is the square of the other. All the usual rules apply.
There is no statistical significance to any of this. Am I missing something??
All this is why statistics are standardized/normalized to the unitless "Z-score."
Including the most important - they have different units. What is bigger, a gallon or a calorie?
@Dale Gracias, si, it maketh no sense to compare ##m^2## with ##m##, but which is a better, the variance or the standard deviation, in giving us an accurate measure of variability, which both I presume are measuring. By squaring (variance), we're amplifying the magnitude of the variability and by taking the square root (standard deviation) we're downsizing the variability (both in terms of pure magnitude). However the magnitude itself conveys no information (vide infra 👇 )
