Why is the result different in Method 2 for the rotating rod experiment?
The discussion revolves around a rotating rod experiment where two methods are used to analyze the motion of rings moving outward. The original poster compares results from two approaches, focusing on angular momentum conservation and energy conservation principles.
  • Mixed
  • The original poster attempts to derive velocities using two different methods, questioning the discrepancies in results. Some participants raise concerns about the validity of the second method, particularly regarding the changing angular velocity and missing units in the equations. Others suggest that the reference frame's dynamics complicate the analysis.
Participants are actively questioning the assumptions made in the second method and discussing the implications of using a non-inertial reference frame. There is a focus on clarifying the equations used and the need for proper unit representation. Some guidance has been offered regarding the interpretation of forces in different reference frames.
There are mentions of missing units and the need for clearer explanations of the equations presented. The discussion highlights the importance of context in understanding the variables involved, particularly with respect to the initial conditions and the nature of the forces acting on the system.
Divya
A rigid horizontal smooth rod $AB$ of mass $0.75 kg$ and length $40 cm$ can rotate freely about a fixed vertical axis through its mid point $O$. Two rings each of mass $1 Kg$ are initially at rest at a distance of $10 cm$ from $O$ on the either side of the rod.The rod is set in rotation with an angular velocity of $30$ radians per second. Find the velocity of each ring along the length of the rod in m/s when they reach the ends of the rod.
(I am new to this forum, I don't know what to write in 'Relevant Equations' field)
Method 1: Simply conserving angular momentum about the the fixed vertical axis and conserving energy gives ##v=3##, which is correct according to my book.
Method 2: Conserving angular momentum when the two rings reach distance ##x## from the centre gives
##(0.01+2x^2) \omega =0.9##
Also in the rod's frame ##a=v dv/dx =\omega ^2 x## (where a and v radial acceleration and velocities).
So, ##v^2/2=\int_{0.1}^{0.2} \frac {0.9xdx} {(0.01+2x^2)^2}=5##.
So, ##v=\sqrt{10}##.
What is wrong in second method?
Edit: Everything is in SI unit
The angular velocity of the rod decreases as the rings move outwards. The formula you used in the second method doesn't work with a reference frame that changes its angular velocity.
There are a lot of units missing.
Why? The fictitious forces are centrifugal, coriolis and azimuthal. Here only centrifugal force is in radial direction. So, the equation should be correct.
Sorry, everything is in SI unit.
These are the forces in a reference frame where the angular velocity stays the same. I guess you could try to do that with the initial angular velocity but it just makes things needlessly complicated.
And it should be added to the quantities that have units. It's a bad habit to not do that, especially combined with equations where quantities are not introduced first. 0.01 is what? Sure, it's possible to guess it from context, but it's just unnecessary. Don't let others guess.
mfb said:
These are the forces in a reference frame where the angular velocity stays the same. I guess you could try to do that with the initial angular velocity but it just makes things needlessly complicated.And it should be added to the quantities that have units. It's a bad habit to not do that, especially combined with equations where quantities are not introduced first. 0.01 is what? Sure, it's possible to guess it from context, but it's just unnecessary. Don't let others guess.
As far I know, in case of non-uniformly rotating frame, everything is same except that we also need to add azimuthal force. And here azimuthal force is not in radial direction.
Plugging in numbers straight away and with no text explanation makes it hard to follow the reasoning. Please explain the derivation of this equation. I was expecting ##x^2\omega=x_0^2\omega_0##.
@haruspex, I have added the explanation of this equation in this attachment.
Ok, thanks.
Your error is that you forgot to square the 0.9.
haruspex said:
Ok, thanks.
I don't think so.
## \omega =\frac {0.9}{0.01+2x^2}##
## \omega ^2=\frac {0.9^2}{(0.01+2x^2)^2}##
Thank you very much.
  • · Replies 31 ·
  • · Replies 18 ·
  • · Replies 25 ·
