- 3,777
- 2,002
yogi said:Janus - let's just concentrate on your statement:
"According to the Earth and Alpha clocks, the Traveler speeds by and crosses the distance in some given time, but due to time dilation, the traveler clock runs slow and thus when it passes Alpha less time will have accumlated on the traveler clock then on either Earth or Alpha."
So you will agree that the traveler's clock does not read the same as clocks in the earth-alpha system at the end of the one-way journey, for whatever reason. We can nail that down I presume - observers on Earth and alpha are reading only Earth synced clocks and the traveler is reading only the clock which has escorted him and when the Earth time on the alpha clock is compared to the travelers clock at the end of the one way journey, the travelers clock has accumulated less time - Am I making the correct conclusion as to this aspect of the experiment?
Only as measured by Earth's and Alpha's Observer. As measured by the Traveler, Earth's and Alpha's clocks have accumulated less time. Assuming that both the Earth clock and Traveler clock read "zero" when they passed each other, then, according the Traveler, the Earth clock will read less than the Traveler's clock when the The Traveler and Alpha pass each other. The Alpha clock will read greater amount of time on it than the Traveler's clock when they pass, not because more time accumulated on Alpha's clock, but because ALpha's clock did not read "Zero" when the Earth and Traveler passed each other, it read some greater time.
If the Earth and Alpha observers are only reading their own clocks, and the Traveler is only reading his own, Then how either can say which accumlated more time according to any of them?
