Why is there a space between two particles of a dipole
  • Context: Undergrad
  • Thread starter Thread starter PurelyPhysical
    Dipole Particles Space
The discussion centers on the existence of space between the particles of an electric dipole, particularly at the microscopic level. It highlights that while opposite charges attract, they do not necessarily combine into a neutral atom, such as hydrogen, due to the nature of molecular bonding. The conversation emphasizes the role of electron affinity, specifically the higher electron affinity of oxygen compared to hydrogen, in the formation of dipoles. Participants clarify that dipoles can exist when non-identical atoms bond, resulting in unequal sharing of electrons.
  • Understanding of electric dipoles and their properties
  • Knowledge of molecular bonding and electron affinity
  • Familiarity with the concepts of protons and electrons
  • Basic chemistry principles regarding atoms and molecules
  • Research the concept of molecular dipoles and their significance in chemistry
  • Explore the differences in electron affinity between various elements
  • Learn about the role of electronegativity in bond formation
  • Investigate the behavior of polar and nonpolar molecules
Chemistry students, molecular biologists, and anyone interested in the principles of molecular bonding and dipole formation.
PurelyPhysical
If you consider an electric dipole, why is it that there is any space between the two particles at all? If both particles of opposite sign attract to each other with equal magnitude, shouldn't they just stick together?
If you are talking about a macroscopic dipole, you just stick two opposite charges to the ends of a plastic rod and you have a dipole. If you are talking about microscopic dipoles at the molecular level, sch as in a water molecule, The formation of opposite charges is a much more complicated affair. You should look up the the relative affinity to electrons of the oxygen atom and the hydrogen atom.
I am referring to microscopic dipoles. I know from chemistry what electron affinity is, and that Oxygen has a higher electron affinity than Hydrogen. So, the particles of the dipole would be oxygen and hydrogen respectively? But then we are considering atoms of different elements as particles of our dipole. Is that the case?
If separate a proton and an electron and then let them come together under their mutual attraction, you will have a hydrogen atom, which is perfectly neutral and not a dipole anymore.
This is what I am referring to. How is it possible for dipoles to exist at the microscopic level, without them simply becoming a hydrogen atom?
I believe Chandra in post #2 touched on that. Molecules behave differently depending on which elements they are composed of. The basic idea is that when two non-identical atoms bond together, their electrons may or may not be shared equally between each other, which can lead to a dipole or higher configuration.
Thank you, that makes sense. I was trying to imagine the particles in the dipole as protons and electrons, being the smallest positive and negative charges I could think of. I had to let go of that idea for this to make sense. Thanks again.
  • · Replies 31 ·
  • · Replies 21 ·
