Optically pumped two level system cannot give rise to population inversion because the the stimulated emission and absorption rate between both levels are equal. Denoting the upper population as ##N_2## and the lower one ##N_1##, the rate equation for ##N_2## is
\frac{dN_2}{dt} = B_{12}I(\omega)N_1 - B_{21}I(\omega)N_2 - A_{21}N_2
where ##B_{12}I(\omega)## the transition probability corresponding to the absorption from the lower to upper states (note that it is proportional to the intensity of the light at the resonant frequency between the two levels because we have assumed optical pumping), ##W_{21}N_2I(\omega)## the transition probability corresponding to the stimulated emission from the upper to lower states, and ##A_{21}## spontaneous emission probability. Now, we have ##B_{12}N_1 = B_{21}## and let's seek out the expression of ratio of the populations at the steady state
\frac{dN_2}{dt} = 0 = B_{12}I(\omega)N_1 - B_{21}I(\omega)N_2 - A_{21}N_2
which can be rearranged to give
\frac{N_2}{N_1} = \frac{B_{12}I(\omega)}{B_{21}I(\omega) + A_{21}} < 1
Thus, optical pumping cannot yield population inversion in a two level atom.
I acknowledge that this part of laser physics has also cast an enigmatic problem in my mind because the above steps was derived under optical pumping condition, this suggests that other pumping methods such as electron collision pumping may be able to lead to population inversion in two level systems. Other sources like
http://spie.org/publications/optipedia-pages/press-content/fg12/fg12_p03_optical_pumping and
http://physics.stackexchange.com/questions/72080/lasing-in-a-2-level-system always specified optical pumping to seemingly safe their argument in case that later two level population inversion can be achieved via non-optical pumping. However, I just found in page 292 in
https://books.google.de/books?id=x3VB2iwSaxsC&pg=PA290&lpg=PA290&dq=population+inversion+with+two+level+system&source=bl&ots=21GKcwzCb9&sig=rBn8cKwKWz221pJEFTupKnW_FuI&hl=en&sa=X&ved=0ahUKEwin8tnv597KAhUMFiwKHQcMDfwQ6AEIUzAI#v=onepage&q=population inversion with two level system&f=false, that at least for electron collision pumping two level inversion is not possible either due to the Boltzmann distribution between the two populations,
\frac{N_2}{N_1} = e^{-\Delta E/(kT_e)}
which cannot even reach unity unless the electron temperature ##T_e## becomes infinity.
