Why Isn't HTML Coding Working in IE11 Anymore?
  • Thread starter davenn
23 replies · 5K views · last reply
Specifically IE 11.0.9600
This has just started over the last week (or two at the most)
Not sure what very recent changes to the forum have happened in the background during this time frame ?
I cannot hilite a bit of text and click B, I, U for bold etc from the selection and make the text bold as in ... it doesn't give the <b> </b> etc
I cannot select a bit of text and select quote and get the <quote> </unquote> around that text
If I manually type the HTML code around the piece of text, it just shows it as text when the post is posted
eg <b>it just shows it as text when the post is posted</b>
text 23
That was supposed to be 2 to the power of 3 I tried to super script the 3 ... doesn't work
It seems that the coding isn't working for anything. I looked in my preferences just in case it can be turned on/off
I didn't see anything obvious ?
This is occurring on my Win 10 PC at home and my Win 7 PC at work ( which I am on at the moment)
Chrome and firefox are doing the html coding OK ,,,, but for various reasons I don't like the way they does other things
and only occasionally use ithem
Dave
I just tried w/ that version and have no problems. Why don't you switch over to a real browser like FireFox ? :smile:
I'm now continuing this reply using 11.0.9600 instead of firefox. What the hell? Now it doesn't work. I have the same problem you reported
OOPS ... I see you already said why you don't use the other browsers.
Trying an original post instead of a reply. Nope, doesn't work here either.
I can only conclude that I slipped a cog and my "try" w/ IE was actually w/ Firefox o:)
Try clicking the little gear icon on the right-hand side of the toolbar for the panel in which you're typing. That toggles the BB-code smart editor on and off... I've found that it often comes up in the toggled-off, which is what you're describing.
Are you talking about the IE "tool" icon?
242993
No. There’s a similar gear icon in the toolbar for the panel you’re composing your message in. It’s right next to the save-draft icon, in the same toolbar as the editing controls.
How about if you use the BBcode square brackets? [b] instead of <b>
Ok, tried that. It just turns all the format options gray. Toggling it again made them come back but they are still useless in IE 11 (this reply was done in IE 11 and formatting doesn't work)
Try opera. It's definitely better than IE. These problems will never occur in a stable version of opera.
Also, as proposed earlier, try using BBcodes instead of html and see what you get.
OK bold Yep that works, but it really isn't a solution to the fundamental problem
yup likewise
Wrichik Basu said:
How about if you use the BBcode square brackets? instead of <b>
yeah it works but that's going to get extremely tedious having to do that a bunch of times in a post
for bolding super/subscripts quotes, media insertion and all the other things in that list
There was definitely a recent change!
The original incarnation of PF5 would refortmat the page to a very narrow column when attempting a Control-Left-Click-Drag to replicate some text.
Now that operation selects ALL the text on the page.
It's a bunch of these little usability backward steps that seem to have me spending a little less time here than I was.
I'm not experiencing that in FireFox
Not seeing it in IE 11 either
Uhmm... did you miss the next sentence?
No, I didn't. It doesn't do either of those things for me. I can select whatever text I want from a post and drag it into the reply box and it all works fine.
When I make a partial selection and then reply as a quote. . . I get this. . :confused:
243000
That doesn't seem right to me ?
phinds said:
I just did the same thing and this is what I got:
Yeah, it works, did it look the same way in the reply box ?
No. I did see what you saw in the reply box but when you "preview" it looks correct and when you post it looks correct. Still, you are right that it shouldn't be doing that.
:check:
Maybe not the day to be saying that, at least if you like extensions and themes.
That has been fixed. . .
Browser extensions need to be signed by Mozilla before they can install...
Above from:
developer.mozilla.org/en-US/docs/Mozilla/Add-ons/WebExtensions/Distribution_options
