Why Does Light Always Go Straight?
  • Context: High School
  • Thread starter Thread starter scilover89
    Light
Light travels in straight lines under normal conditions, but this is an approximation based on classical optics. In quantum mechanics (QM), photons can take multiple trajectories, yet their probability distribution is predominantly concentrated along a straight path. Richard Feynman's principle of least action explains that light follows the path of least resistance, which is typically a straight line. However, Feynman's sum-over-histories indicates that photons can theoretically travel faster or slower than the speed of light, c, but these paths combine to yield the conventional speed of light.
  • Understanding of quantum mechanics principles
  • Familiarity with Richard Feynman's sum-over-histories approach
  • Knowledge of classical optics and the principle of least action
  • Basic grasp of probability distributions in quantum physics
  • Study Richard Feynman's "QED" for insights on photon behavior
  • Research quantum mechanics concepts related to probability distributions
  • Explore the principle of least action in physics
  • Investigate the implications of faster-than-light theories in quantum mechanics
Physicists, students of quantum mechanics, and anyone interested in the behavior of light and photons in both classical and quantum contexts.
scilover89
In normal condition, light always go straight. But since photon move randomly, why must they go straight?
What do you mean by this ?
Straight with respect to what? Photons usually do take random paths, but they travel on geodesic paths once they chose a course. After that, they appear to travel along the same path, until disturbed.
I think the OP may be confusing the random choice of a direction with the randomness that is associated with Brownian motion or the drunken walk.
I think what the thread starter wanted is actually said in one of Feynman's books. In classical optics, light is seen as traveling in straight lines, but that is shows as an approximation of what really happens. Using the principle of least action, light does indeed travel in a straight line since that's the easiest path to travel.
But according to QM, a photon can take several crazy trajectories, but if looking at the probability cloud of a photon, its mostly concentrated in a straight line. So in the context of QM, light doesn't really travel in straight lines, it just MOST PROBABLY would travel in a straight line.
Am i right on this one?
^ at what speed does it travel on those other paths?
"c" 299 792 458 m/s
A photon in Feynman's sum-over-histories has countless paths faster and slower than the speed-of-light that combine to give the speed-of-light path.
We have to be careful not to think of a particle as having anything like a definite position and velocity at the same time, though, but we can describe it as series of definite positions at all times so as to make up these paths for the sum-over-histories, I think.
Really? I did not know this. Could you elaborate more on this or maybe suply me with a link. If this topic has a name I'll google it.
Actually, the "slower than light" bit I mention might not be right for photons. I remember now that was something I meant to check to see if it was a possibility. Oops. :blushing:
I know that faster than light and even backwards in time histories are correct and appear in a sum-over-histories, though. :smile:
Professor Feynman to the rescue! I was right about the slower than light histories for photons in a sum-over-histories. That's a relief. :biggrin:
To quote Richard Feynman "...there is also an amplitude for light to go faster (or slower) than the conventional speed of light. You found out in the last lecture that light doesn't go only in straight lines; now, you find out that it doesn't go only at the speed of light! It may surprise you that there is an amplitude for a photon to go at speeds faster or slower than the conventional speed, c." - Chapter 3, page 89 of Richard Feynman's book "QED".
Got that from:
http://en.wikipedia.org/wiki/Faster_than_light
"Momentum" is the explanation that usually serves my purpose.
Photons do not move randomly. QM is not just all about randomness - there are very strict rules about how objects can behave. In order to decide the probability that some system will start in classical state A and end in classical state B, we do the Feynman cookbooking (i.e. e^{\frac{i}{\hbar}S} where S is the classical action of that history, and then sum this value for every possible history to get the probability (to within some proportionalirt factor) that the system will truly go from state A to state B). So it's not all random, there are precise rules. It was designed so that for macroscopic systems, the outcome is exactly the same as the classical outcome.
  • · Replies 39 ·
  • · Replies 24 ·
  • · Replies 34 ·
