Why operating pressure is different for propane and butane
  • Thread starter Thread starter Jehannum
    Pressure Propane
In UK LPG installations, propane is regulated to 37 mbar while butane is set to 28 mbar. The difference in operating pressures is primarily attributed to the boiling points of the gases rather than their calorific values. Propane's higher pressure compensates for its lower calorific value compared to butane, ensuring efficient combustion in gas-burning appliances. The discussion highlights the importance of understanding gauge pressures and their implications on flow rates and appliance compatibility.
  • Understanding of LPG (Liquefied Petroleum Gas) properties
  • Knowledge of gauge pressure vs. absolute pressure
  • Familiarity with calorific values of propane and butane
  • Basic principles of gas combustion in appliances
  • Research the boiling points of propane and butane and their impact on gas flow
  • Learn about the differences in appliance requirements for propane and butane
  • Study the effects of pressure differentials on gas flow rates
  • Explore regulations governing LPG installations in different regions
Gas engineers, appliance manufacturers, and anyone involved in the installation and maintenance of LPG systems will benefit from this discussion.
Jehannum
TL;DR
In UK LPG installations, propane is regulated to 37 mbar and butane to 28 mbar. Is my guess at the reason for this correct or is it just a coincidence?
It's desirable that propane and butane be interchangeable as fuels in gas-burning appliances. However, butane has a higher calorific value. If used at the same pressure as propane it would give a higher heat output.
My guess was that the reason propane is set to a higher pressure is to offset its lower calorific value (CV).
Numerically, if you multiply 28 mbar by the ratio of CVs of butane to propane (122 / 93) you get (near enough) 37 mbar.
This made sense at first but I later realized that these are gauge pressures. I might expect this simple ratio relationship to work on absolute pressures but not gauge pressures. So now I'm thinking it's just a coincidence.
I train people on this stuff, so I need to get it right. I would appreciate any input.
My guess is it is a function of boiling point, not heating value. If the boiling point at the storage temperature is too high, it won't boil [fast enough].
In the US, appliances are not interchangeable between natural gas and propane; they need different valve orifices and air mixtures. But I don't know about butane.
Jehannum said:
Summary:: In UK LPG installations, propane is regulated to 37 mbar and butane to 28 mbar. Is my guess at the reason for this correct or is it just a coincidence?
Isn't the flow rate determined by the pressure differential? Seems to me that it should be gauge pressure.
9K
10K
  • · Replies 133 ·
28K
