Why P = F*v = ε^2/R = (vBl)^2/R when there's no friction?
  • Thread starter Thread starter Karagoz
    Friction Power
6 replies · 2K views
Karagoz
This is taken from a problem with its solution. But there's one thing I didn't understand with the solution:
A closed conductor loop is located perpendicular to the field lines in a homogeneous magnetic field B. The conductor slice CD is first in rest. Then we pull a constant force F to the right. See figure above. The absolute value of the force is 1.8 N. The conductor slice slides without friction.
After a while the speed v is constant and is equal to 4.0 m/s. The length of the conductor slice CD is 12 cm.
The electrical power in the circuit is given by:
The effect of the pull force F is given by: P = F*v
Since we do not have friction, these powers must be the same. And this gives:
How is it that the effect on the pull force P = F*v is equal to the electrical power in the circuit given by:
What's the proof?
P = F*v
P = ε^2/R = (vBl)^2/R
[/B]
You can calculate the current ##I## from Faraday's Law. You can then do two separate calculations, (a) find the force from ##F=IlB## and (b) find the power dissipated in the resistor from ##P=I^2R##. If you put the two expressions side by side, you will see that ##I^2R = Fv##.
On edit: When the rod is moving at constant speed (terminal velocity), the net force on it is zero, and that's when the magnetic force ##IlB## matches the externally applied constant force ##F##.
But how can we find current using Faraday's law? We can only find ε using Faraday's induction formula.
How is P = F*v derived form P = I^2*R in this case?
Using Ohm's law.
What did you not understand in #2?
(I use capital L instead of l to make it easier to read).
Power formula: P = U^2/R
Faraday's law: U = vBL (I use U instead of ε)
Into the power formula:
P = (vBL)^2 / R
Formula for speed from Faraday's formula:
U = vBL
v = U/BL
Formula for the force on a conductor slice:
F = ILB
Current:
I = U/R
Into the formula for the force:
F = U/R * LB = ULB/R
Both the speed and power formula into the speed formula:
F*v = U/BL * ULB/R = U^2/R = P.
P = F*v = U^2/R.
P = (vBL)^2 / R
U = vBL
v = U/BL
F = ILB
Current:
I = U/R
P = F*v = U^2/R.
Looks good!
Is there any question?
cnh1995 said:
Looks good!
No, I got it. thanks
