- 18
Once again it seems you are inventing your own language, rather than using the standard language of physicists. What are the precise criteria for something to be treated as "a dimension" in physics, according to you? Would you disagree that any variable one chooses--temperature, say--can be considered a dimension?MeJennifer said:In pre-relativistic kinematics and dynamics time is indeed a dimension but not in relativity.
What does the phrase "not expressed as a dimension" mean you you, exactly?MeJennifer said:Time in space-time is proper time which is not expressed as a dimension
You could similarly say that space in ordinary 2D euclidean geometry is expressed by a metric with two dimensions--but this wouldn't justify the statement that an x-axis and a y-axis placed on this space cannot themselves be described as "spatial dimensions", it's standard terminology in mathematics to refer to them that way.MeJennifer said:but is expressed by the metric of space-time, and this metric is composed of four separate dimensions.
If you take a bunch of clocks radiating out from a single event at different velocities, with each reading t=0 where their worldlines intersect this event, and then draw a hypersurface based on the event of each clock reading the same proper time t=T, then sure, you get a hyperbola. But what does this have to do with whether time is "a dimension"?MeJennifer said:As I wrote before, the hypersurfaces of constant proper time of space-time are hyperbolic.
I still don't get what point you think you're making here. If you like you are free to use a coordinate system where the t-coordinate is based on the proper time along worldlines radiating out from a single event (although the coordinate system can only cover the future and past light cone of that event), but you'll still need four coordinates to pinpoint any event in the region covered by the coordinate system, and there'll still be an unambiguous notion of whether the separation between two events is timelike, spacelike or lightlike (though I think in this coordinate system it'd be possible for two events to have the same t-coordinate but a timelike separation). And the conventional coordinate systems used in SR can also be understood in terms of the proper time on physical clocks, except that instead of using a collection of physical clocks radiating out from a single point in spacetime at different velocities, you have a collection of clocks at rest with respect to each other and synchronized according to the Einstein synchronization convention. In this case if you look at the hypersurface of constant proper time (the event on each clock's worldline where it has ticked some time T since t=0), then you have the standard surface of simultaneity of an inertial coordinate system in SR. Leaving aside the question of why you think your choice of coordinate system shows "time is not a dimension", do you think that your choice of coordinate system, based on the proper time of clocks radiating out from a single event and all set to read the same time where their worldlines intersect that event, is somehow more "physical" than this one, based on the proper time of clocks at rest with respect to each other and synchronized according to the Einstein clock synchronization convention?MeJennifer said:These hypersurfaces could only overlap the hypersurfaces of constant t (for the commonly called "time" dimension) in the case the speed of light would be infinite.
I don't understand what diffeomorphism invariance has to do with "doing away with time", or what you mean by "each instance in time"--each instance of what, exactly? Would you agree that the question of whether two events are timelike separated, spacelike separated, or lightlike separated is a physical issue which is not affected by your choice of coordinate system?MeJennifer said:Actually, if you want to, in relativity, you can do away with time. The theory is diffeomorphism invariant and that means that each instance in time is simply the same thing just in another format.
