Why the quantum: a response to Wheeler's 1986 paper
395 replies · 34K views
atyy said:
Of course classical mechanics is a limit of quantum mechanics. One can see this in the saddle point approximation to the path integral.
However, what you are not understanding and which Landau and Lifshitz state clearly, is that quantum mechanics cannot be formulated without "classical concepts" also in its assumptions. It is not possible to derive classical physics from "purely quantum" assumptions.
One can use different language to state this assumption, but they are all essentially equivalent - measurement has a different status than the interactions described in the Hamiltonian.
QT is about what's observable in nature, and to observe we need macroscopic objects, which are describable to sufficient accuracy with classical physics. That's all what LL state in their marvelous textbook on QM, and since the validity of the classical limit can be understood from QM there's no contradiction in that, i.e., there are no special laws for macroscopic objects (i.e., no quantum-classical cut) and no specialty of measurement devices in terms of the physical description in theory from any other kind of matter, which is self-evident, because obviously measurement devices must be made of the matter around us. They are only special in the sense that physicists construct them to measure the one or the other observable, but they are still consisting of the matter around us. Of what else shoud they be made?
So indeed I agree with the statement that to understand measurements one needs classical concepts, but that doesn't mean that a measurement is anything different from any other interaction of the measured system with a macroscopic object that's not used as a mesurement device.
vanhees71 said:
The "preferred basis" is just the observer's choice which observable s/he likes to measure.
This is not true. Given the measurement device as a quantum object, the observer has no choice which observables to measure - it can only measure the observables that can be read off from (or calculated from reading of) the measurement device.Thus there must be a way to determine the preferred basis directly from the quantum device, without choices by a further observer.
There you have made the subjective classical-quantum cut.
vanhees71 said:
But also #2 doesn't distinguish measurements from other interactions.
And yet, you have admitted that you don't use the Born rule inside the Schrödinger equation. That clearly means that there is no "preferred base" picking in QM interaction. None.
Really ? Just ? So it should be easy for you to provide a derivation (without any cut) of the Born rule. This must be an very interesting proof, because it will DEFINE what a measure is. It would be the first theory to actually create its own version of what an observation is, not related to an event in a lab, but to some VAGUELY defined ensemble of events.
Thus, you'll have to make another theory leap, to explain how measurement that only are coherent for ensemble (and basically, that this is probabilistic or not, is not even relevant here) will still actually physically modify (set in an eigenstate) only individual system, and not ensemble.
That's the only meaning in which a basis has to be chosen to evaluate probabilities: To get the probabilities for the outcome of measurements you need the eigenbasis of the self-adjoint operator representing this observable. It's not more special then the observer's choice in classical physics too. If I measure the position of a particle I need another device than when I measure its momentum.
You've just said you cannot measure the position of a particle (only a probability in an ensemble). In fact "speed" it does not exist in the interaction picture (its a complex mixture of imaginary speed)
Whatever your version of QM is, individual particles have no speed or momentum or whatnot. And yet, nature only "hidden ontology", can only be approached and probed, (and this is even more true in QM), with unique individual event in the lab (and that is a that individual level, that all conservation law work).
Your view that only "ensemble of identically prepared thing" exist, and this is a complete physical phenomenology of nature, is highly incoherent with the fact that quanta do exist, and only them, and their individual interaction, are ever observed in a laboratory, or elsewhere.
A. Neumaier said:
This is not true. Given the measurement device as a quantum object, the observer has no choice which observables to measure - it can only measure the observables that can be read off from (or calculated from reading of) the measurement device.Thus there must be a way to determine the preferred basis directly the quantum device, without choices by a further observer.
Well, this is semantics. The observer constructs the measurement device to measure the observable he likes to measure. If you now start to discuss the ability of this free choice of the observer to measure the observable he likes you get into funny discussions about "consciousness" and "free will" and all kinds of esotrical philosophy around it. I was shocked to see that this is even publishable in serious scientific publishing companies like Springer. Well, there's no law forbidding to publish nonsense in serious science publishing companies, which like to make money with anything they can find. A funny anecdote is that when I went into a big bookshop in Munich to look for quantum theory textbooks I couldn't find it in the very small science corner of this bookshop. Asking a nice employee of the bookshop, whether they don't have also quantum theory textbooks, she answered "Oh, you are complete wrong here. That's in the shelf with book on esoterics, which in fact was much larger than the little shelf they sold science textbooks." Well, they had no quantum theory textbooks but all kinds of "quantum nonsense" (as Bricmont calls it in his book "Quantum sense and quantum nonsense", of which I currently read the German translation; it's pretty entertaining to read although sometimes rather imprecise in popularizing QT; I also don't buy the "solution" of the interpretational problems in terms of de Brogli-Bohm theory since so far nobody could make sense of it in context relativistic QFT).
Not again this wrong statement. You cannot admit at the same time that the classical behavior is derivable from QT and then claim that there is a cut. That's a contradictio in adjecto!
Quantum objects have all the observables which can be defined on them. For massive particles these are particularly their energy, momentum, angular momentum, and their position. The point in QT is that not all the observables can take determined values at once (some cannot take determined values at all, which is the case for all observables having a continuous spectrum only like energy, momentum, and position).
That's not what I claim. Of course single electrons exist, and we can prepare them in many quantum states quite accurately. All I say is that within the ensemble interpretation quantum theory only describes the probabilities, and these probabilities can be empirically measured only on ensembles of equally prepared systems.
I don't object to the choice. But after the observer has chosen the device (by whatever rule), there remains the pure quantum problem to show that the device actually produces on each reading the numbers that qualify as a measurement, in the sense that they satisfy Born's rule.
This is the measurement problem! It has nothing to do with the observer but is a purely quantum mechanical problem.
But each individual system produces definite result (or appears to produce definite result). And either you have something to say about that, and then you participate in discussions about "collapse" and alternatives, or you keep agnostic position and do not say anything like "collapse is superfluous"/"collapse is required".
So far so good...
No you cannot. There is no phenomenon as "state preparation" in nature. You (the observer) only do it in a lab, because you need that to match the ensemble with the esoteric Hilbert space, by using an ad-hoc Born rule. This ensemble exist only in your head. CM does not need any ad-hoc projection for observation, nor does nature (as per QM Schrödinger equation).
You say much more then that. You made make hidden assumptions (often circular) and quite astonishing claim (like QM completeness). You say noticeably that there is no epistemological difference with CM.
But in CM you don't need to make measurement to "create" the value of any observable (out of probability or whatnot).
There is a difference between this and the statement that QT doesn't make any predictions without a cut.
Ok, that's true. Of course, it's only possible for very simple cases in a strict way (like the famous analysis of tracks of charged particles in vapour chambers by Mott or the measurement of spin components in the Stern Geralach experiment).
Boing3000 said:
So far so good...
No you cannot. There is no phenomenon as "state preparation" in nature. You (the observer) only do it in a lab, because you need that to match the ensemble with the esoteric Hilbert space, by using an ad-hoc Born rule. This ensemble exist only in your head. CM does not need any ad-hoc projection for observation, nor does nature (as per QM Schrödinger equation).You say much more then that. You made make hidden assumptions (often circular) and quite astonishing claim (like QM completeness). You say noticeably that there is no epistemological difference with CM.
Of course we can handle electrons pretty well in accelerators and thus prepare, e.g., electrons with a pretty well determined energy and momentum to make all kinds of scattering experiments with them for decades. The ensemble doesn't exist only in my head, but it's realized with accelerators. That's why they aim at ever higher luminosities to "collect statistics as quickly as possible".
I don't claim the completeness of any physical theory we have so far. QM is incomplete because there is no satisfactory quantum description of the gravitational field yet. Indeed, I don't see any epistemological difference with CM. There's an ontological difference though.
Circular reasoning. You cannot prepare an electron in a pretty well defined state without measuring it first
The ensemble preparation is an laboratory artifact. You cannot, in the real world (or even based on QM phenomenology), propose an experiment to "ask/probe" an electron to find its companions in "an ensemble". This ensemble is not real. And the prediction are only more and more accurate with respect to the ensemble size.
CM does not need an ad-hoc rule to connect the evolution formalism to the lab event. It does not need ensemble either. And CM don't treat measurement and interaction differently.
Because "ensemble" can not be defined in terms of QM, minimal QM is not a selfcontained model. It requires CM as a starting platform.
I think it definitely does.You measure a property and you get an eigenvalue ##\lambda## of the operator corresponding to the observable being measured. That means that the measuring device is in a specific state---the state of "having measured ##\lambda##". But treating the device as a physical system and treating the measurement as a physical interaction leads to a different state--where the measuring device is not in a specific state, but is entangled with the system being measured. Those are two different situations in QM, and are described by different quantum-mechanical states and those states have theoretically different statistical properties, leading to different predictions for future states. The two possible quantum-mechanical states are different, with different (in theory) observable consequences. They can't both be correct.
Now, I stuck the phrase "in theory" in there, because I think that the difference between an entangled macroscopic system and one that has a specific macroscopic properties may be undetectable in practice, but they are different states in QM. So you get different answers depending on whether you're treating the macroscopic system as a physical system following Schrödinger's equation or as a measuring device obeying the Born rule.
That's my feeling. A true minimalist interpretation, in the sense of making minimal assumptions, is not a denial of the collapse interpretation or the Many-Worlds Interpretation or the Bohmian interpretation, but should open to any of those possibilities. It should be silent on the question of what happens during a measurement.
Which version of Landau and Lifshitz are you reading? Perhaps the German translation is different from the English one. There is a possibility the English version is biased towarda my views, since John Bell apparently had a role in it.
The english translation of that section is faithfull to the original russian text.
The ensemble preparation is an laboratory artifact. You cannot, in the real world (or even based on QM phenomenology), propose an experiment to "ask/probe" an electron to find its companions in "an ensemble". This ensemble is not real. And the prediction are only more and more accurate with respect to the ensemble size.CM does not need an ad-hoc rule to connect the evolution formalism to the lab event. It does not need ensemble either. And CM don't treat measurement and interaction differently.
How do you come to these conclusions? We can prepare single electrons, even single photons, very well nowadays. And an ensemble can (among other ways to prepare them) consist of many repetitions of such single-quanta states. If this was not the case, we couldn't have ever checked that QT is describing things right in terms of the predicted probabilities.
Quantum mechanics doesn't treat measurement and interaction differently (I won't again repeat the obvious arguments I've stated several times in this thread again).
The circularity of that claim is obvious.
But maybe that "preparation" is yet another kind of physical process I am not aware off, and described in your version of QM that is neither interaction nor measurement.
OK then how do you prepare an entangled pair of electron or photon that have probability 1 to be polarized at such angle along such axes...
But maybe that "preparation" is yet another kind of physical process I am not aware off, and described in your version of QM that is neither interaction nor measurement.OK then how do you prepare an entangled pair of electron or photon that have probability 1 to be polarized at such angle along such axes...
I'm sort of in agreement with you that in QM, measurement and preparation seem very similar, but there are some circumstances where it is possible to get particles in a particular state without measuring them. For example, if you send electrons through a Stern-Gerlach device, the ones that are spin-up will go in one direction and the ones that are spin-down will go in another direction. Then if you perform an experiment on just one of the two streams, you can be assured that the electrons are in a specific spin state even though you didn't measure the spin.
But didn't you just describe a measurement ? How can you say you didn't measure their spin ? Or are you saying you are no more interested by spin, but want to measure some other property (maybe loosely coupled with spin) ?
I agree this process is important, and this is where the probabilistic abstractions are attached to physics.
This requires two things to actually make sense:
- The timescale of the processes we observer must be "small" so that we can prepare, decode data, and repeat enough statistis fast on a relative timescale
- The experimental control requires the system of study to be small relative to the lab so that we can control its boundary.
This is certainly true for HEP where we can observe scattering on the boundary, but fails for cosmology (here a new paradigm for inference is needed! which one?)
If we can do this we have good foundation for the probabilistic predictions, as well as extracting timeless patterns that stay constant over trials (symmetries). This how the standard model of particle physics is designed. But if these premises fail, not only do "probability" loose its original meaning, we also loose the ability in inferring symmetries, either because its too much data and limiting processing power or because of insufficient data to with any reasonable accuracy make statistical statements.
/Fredrik
No. After sending an electron through a Stern-Gerlach device, I know that:
  • If the electron went left, then it must have been spin-up
  • If the electron went right, then it must have been spin-down
But I don't know which is the case, so I haven't actually measured the spin.
Do you mean someone else have chosen which stream (left or right, or apparatus angle) and that you just don't know on which one you are working on ?
Well, it depends on exactly what is done with the two streams. If I perform a measurement of the electrons that go through one of the streams and get some result, then I'm indirectly measuring which stream the electron went in (since only one of the streams is measured), and so that indirectly counts as a spin measurement. But the measurement occurs at the moment I measure something about the electron. The separation into streams did not constitute a measurement.
To see that the separation by itself is not a measurement, I could redirect both streams back together into a single stream, and then no measurement of spin would ever be performed.
So a preparation does not necessarily count as a measurement (although it can be a preliminary step in a measurement).
If you recombine the beams you do not get a thermal state, but you may have had one before the projections (depending on your preparation !) .
All projective 'measurements' are preparations. Nothing has been measured and all information about the previous state is lost.
This is elementary stuff which most people choose to ignore.
I'm not sure what you mean. Suppose I do the following:
  1. Start with a stream of electrons that are spin-up in the x-direction
  2. Separate it into two streams by sending electrons that are spin-up in the z-direction to the left, and the ones that are spin-down in the z-direction to the right.
  3. Now, I recombine the two beams into a single beam
  4. Finally, I measure the spin of the combined beam in the x-direction
If step 2 were a measurement, then step 4 would yield spin-up or spin-down, with equal probability. If step 2 is not a measurement, then step 4 will only produce the result spin-up.
If a coherent state is prepared before the splitting/recombination and coherence is maintained then there will be state reconstruction. In those circumstances the splitting is a 'reversible measurement' because it tells us nothing about the previous state - i.e. like having no 'which-path' information.
