Why use spread operator when sorting an array in JavaScript?
shivajikobardan
TL;DR
spread operator javascript
I Understand the basic theory behind spread operator.
JavaScript:
const girlNames = ['Jessica', 'Emma', 'Amandine']
const newGirlNames = [...girlNames]
console.log(newGirlNames)
// Output: ["Jessica", "Emma", "Amandine"]
But I don't understand when it's applied. See here.
JavaScript:
function createList() {
  [...richestPeople]
    .map(a => ({ value: a, sort: Math.random() }))
    .sort((a, b) => a.sort - b.sort)
    .map(a => a.value)
    .forEach((person, index) => {
      const listItem = document.createElement("li");
      listItem.setAttribute("data-index", index);
      listItem.innerHTML =
    <span class="number">${index + 1}</span>
    <div class="draggable" draggable="true">
    <p class="person-name">${person}</p>
    <i class="fa-solid fa-grip-lines"></i>
    </div>
      listItems.push(listItem);
      draggable_list.appendChild(listItem);
Why do we require spread operator here? I tried to see the output w/o spread operator and seeing that didn't help.
output with spread operator:
Screenshot of a webpage titled '10 richest people' with a drag-and-drop ranked list: 1 Warren Buffett, 2 Elon Musk, 3 Larry Page, 4 Sergey Brin, 5 Bernard Arnault, 6 Jeff Bezos, 7 Larry Ellison, each with a grip handle and a 'Check order' button.
output without spread operator:
Browser page titled 10 richest people, with a Check order button, a numbered list item 1, and the names Jeff Bezos, Elon Musk, Bernard Arnault, Bill Gates, Mark Zuckerberg, Warren Buffett, Larry Ellison, Larry Page, Sergey Brin in one line.
It must be obvious to people, but it's not to me. I'm not getting it.
This suggests that [...arr] is an efficient way of creating a copy of the one-dimensional array arr. Without the operator, you have [arr], an array consisting of a single entry, namely arr. Hence your second screenshot has the entire list of names as a comma-separated string in a single <li> tag, rather than each name in its own <li> tag as in the first screenshot.
shivajikobardan said:
JavaScript:
  [...richestPeople]
You don't. The code below has exactly the same result.
JavaScript:
  richestPeople
But note
JavaScript:
// This sorts the array richestPeople.
richestPeople.sort();
// This creates a new array of the elements of richestPeople and sorts it.
// richestPeople is left unsorted.
sortedRichestPeople = [...richestPeople].sort();
// This code has an identical result and is preferred by some:
sortedRichestPeople = richestPeople.slice().sort();
