Winning Lines for Tic-Tac-Toe (C programming)
5 replies · 6K views · last reply
galaxy_twirl
The Question
Winning Lines
Tic-tac-toe is a game played by two players o and x. A player wins when he/she succeeds in placing three respective marks in a horizontal, vertical or diagonal row.
Given a 3-by-3 tic-tac-toe board, a winning line is a line (row, column or diagonal) that is not blocked by the opponent. For example, given the sample board below:
xox
.o.
..x
  • player x has three winning lines --- first and last column, as well as the last row
  • player o has two winning lines --- the middle row and middle column
Write a program that reads a 3-by-3 tic-tac-toe board and determines the winning lines of both players. Assume that the board represents a valid play.
Sample runs:
The following are sample runs of the program. User input is underlined. Ensure that the last line of output is followed by a newline character.
  • Sample run #1:
    Enter board:
    xox
    .o.
    ..x
    x winning lines: 3
    o winning lines: 2
  • Sample run #2:
    Enter board:
    .ox
    .ox
    ..x
    x winning lines: 3
    o winning lines: 2
  • Sample run #3:
    Enter board:
    xox
    xoo
    oxx
x winning lines: 0
o winning lines: 0
I ran into slight difficulties while trying to look for a pattern to obtain the algorithm for the above. However, I managed to come up with following:
1. Max. possible number of winning lines: 4 (occurrence: When I have two of the same type (x or o) side-by-side in the middle of the tic-tac-toe sheet.
2. If a symbol is in the middle box and its surrrounding (up, down, left, right) are clear, max winning lines = 3.
3. If a symbol is at the four corners, and there are no opposite symbols on its vertical, lateral and diagonal sides, max winning lines = 3.
4. General: If a symbol has "."s on its lateral, vertical or diagonal axes, it can form a winning line.
I wrote the code below:
Code:
#include <stdio.h>
#define ROW 3
#define COL 3
void fillArray(char arr[][COL]);
int numWin(char arr[][COL], int count);
int main(void)
    char arr[ROW][COL];
    int x=0, o=0;
    fillArray(arr[][COL]);
    numWin(arr[][COL], count);
    printf("x winning lines: %d\n", x);
    printf("o winning lines: %d\n", o);
    return 0;
     int i=0, j=0;
     for(i=0;i<ROW;i++)
         for(j=0;j<COL;j++)
             scanf(" %c", &arr[i][j]);
int xWinline(char arr[][COL], int count) //Too tired to continue. :(
    int i=0, j=0;
    for(i=0;i<ROW;i++)
         for(j=0;j<COL;j++)
             if(char[i][j] == ".")
                 return 0;
May I have some help please? Thank you! :)
There are 8 different possibilities for a win in a tic-tac-toe game. You need to monitor the board separately for both players and return a win if one of the players satisfies one of the eight winning conditions.
For example, using an ##int## based implementation that passes the game board in:
Code:
int winCheck (const int gameBoard[]) {
  //8 Different possibilities for a win in a tic tac toe game.
  //== 10 means the spot is taken by 'O'.
  //== 11 means the spot is taken by 'X'
  if((gameBoard[0] == 10 && gameBoard[3] == 10 && gameBoard[6] == 10)
  || (gameBoard[1] == 10 && gameBoard[4] == 10 && gameBoard[7] == 10)
  || (gameBoard[2] == 10 && gameBoard[5] == 10 && gameBoard[8] == 10)
  || (gameBoard[0] == 10 && gameBoard[1] == 10 && gameBoard[2] == 10)
  || (gameBoard[3] == 10 && gameBoard[4] == 10 && gameBoard[5] == 10)
  || (gameBoard[6] == 10 && gameBoard[7] == 10 && gameBoard[8] == 10)
  || (gameBoard[0] == 10 && gameBoard[4] == 10 && gameBoard[8] == 10)
  || (gameBoard[2] == 10 && gameBoard[4] == 10 && gameBoard[6] == 10))
  return 0;
  else if((gameBoard[0] == 11 && gameBoard[3] == 11 && gameBoard[6] == 11)
  || (gameBoard[1] == 11 && gameBoard[4] == 11 && gameBoard[7] == 11)
  || (gameBoard[2] == 11 && gameBoard[5] == 11 && gameBoard[8] == 11)
  || (gameBoard[0] == 11 && gameBoard[1] == 11 && gameBoard[2] == 11)
  || (gameBoard[3] == 11 && gameBoard[4] == 11 && gameBoard[5] == 11)
  || (gameBoard[6] == 11 && gameBoard[7] == 11 && gameBoard[8] == 11)
  || (gameBoard[0] == 11 && gameBoard[4] == 11 && gameBoard[8] == 11)
  || (gameBoard[2] == 11 && gameBoard[4] == 11 && gameBoard[6] == 11))
  return 1;
  else
  return -1;
The code returns ##0## if 'O' is the winner, ##1## if 'X' is the winner, or ##-1## if no one has won the game yet.
This of course is not the only implementation. You could use chars or bools if you prefer. The important thing is to understand how a win is achieved.
A much simpler solution is to initialize all cells to 0, and fill the appropriate cells of a particular game with 1 in place of 'O', and -1 in place of 'X'. Then, after the game is laid out, add each of the three rows, three columns, and two diagonals. If a row, column, or diagonal adds to 3, the 'O' player wins. If a row, column, or diagonal adds to -3, the 'X' player wins. Any other combination results in a tie.
I am assuming that no game would be input that had both the 'O' player and 'X' player as winners.
Zondrina, Mark: perhaps I am missing something, but the definition of a winning line OP posted makes both your answers wrong. It is not about finding who won the game, as lines with empty fields still count as winning lines (... is a winning line for both players), even if the game has not yet ended.
You're right. I missed this definition in the OP:
I'll have to give this some more thought.
Hi everyone. Thank you for replying to my question. :) I think I will leave this question for a while as I have to tend to my other subjects which I am also struggling in. >< Sorry. I will come to this soon~ Thank you all once again.
