Work and enegry theoretical problem
6 replies · 4K views · last reply
chazgurl4life
Ok so my problem was: A 80 kg hiker starts at an elevation of 1600 m and climbs to the top of a 3600 m peak.
(a) What is the hiker's change in potential energy?
J
(b) What is the minimum work required of the hiker?
J
(c) Can the actual work done be more than this? YES!
so i figured out a) Change in PE = mg(y2-y1)
=80kg(9.8 m/s^2)(3600m-1600m)
= 1.56 x 10^6 Joules
B) Part b is the same answer cause with your PE you can perform minimum work
But for C i don't understand how the actual work be more than delta PE?
Ok ..if we consider friction t the opposite force ( energy used to climb up the peak) has to be more than 1.5 e6 because it has to overcome the force of friction to kepp climbing up. is that right?
im going to ask my professor in class thanks anyway
