Why is Work Calculated as Fdcosθ Even with Gravity?
  • Thread starter Thread starter vivekfan
    Conceptual Work
Work is defined as the dot product of force and displacement, represented by the equation Fdcosθ, where θ is the angle between the force and displacement vectors. This definition applies universally, including when calculating work done by gravity. Work is a scalar quantity, meaning it has magnitude but no direction. The cosine factor accounts for the angle between the force applied and the direction of movement, which is crucial for accurate calculations. Understanding this concept is essential for grasping the principles of mechanical work.
vivekfan
This is conceptual question...Is work a scalar or vector quantity? Is it force times distance or displacement?
And it just Fdcostheta by definition of the dot product. Why is it cos theta even when you calculate work done by gravity?
Fdcos theta
Just need conceptual clarification.
hello,
just check http://en.wikipedia.org/wiki/Mechanical_work"
I suppose,it helps.
Dot product of two vectors is scalar :smile:
  • · Replies 19 ·
