Work out force transmitted to sensor
  • Thread starter Thread starter Engineer101
    Force Sensor Work
31 replies · 3K views
Engineer101
There is a wind tunnel force balance allowing the
measurement of the drag force resultant at point A of a test object in the air
stream from an arm and lever system mounted on a pivoting point O and
pressing onto a force sensor at point B.
1) What will be magnitude of the force transmitted into the sensor at B if the air
flow results in creating a lift force of 1.75 N and a drag force of 1.20 N?
I couldn't paste in the picture it wouldn't let me. but there is a 90 degree lever with the first part of the lever being vertical in the direction of lift and is 1.2m long. There is then a pivot, O, and to the right of that at 90 degrees is a horizontal part of the lever and is 0.5m long. sensor B is underneath this part so that when drag occurs it will push on the lever and push down onto B.
2) Calculate the horizontal component Ox and vertical component, Oy of the transmitted force in pivoting point O.
(Consider the coordinate system used to be positive in the direction against the airflow for the x component, and positive in the upward direction for y)
Give your answer in Newtons (N)
Pythagoras?
question 1 - The sensor is used to measure lift so is the answer simply 1.20N?
I tried resolving the force and then did some moments but then realized I only need an answer in Newtons and I would get an answer in N/m.
question 2 - is it -1.20 since the force transmitted is in the opposite direction to airflow? and vertical component 0? I'm confused because the lengths of the lever arms seem to be irrelevant.
This is my first post, thank you for reading and helping if you can!
Thanks.
Engineer101 said:
question 1 - The sensor is used to measure lift ...
Is it? The problem statement says..
measurement of the drag force...
The answer isn't 1.2N. There are levers of different lengths involved.
Sorry I meant to say drag,
So how do you work it out then? Because why would you have a sensor that measures drag that doesn't read 1.2N?
Thank you!
(For Q1) This diagram is effectively the same problem. Any easier to understand?
The question doesn't ask what the sensor displays it asks for the "force transmitted into the sensor"
Ah that is a bit easier, is it 0.5N then?
CWatters said:
Try again. Have a look at the length of the levers. Will the force be greater or less than 1.2N ?
Actually it would be more, but how do you do it without getting the answer in Newton Meter's? Is it 2.88N?
Thanks
Correct.
Torque = force * distance
= 1.2N * 1.2M
= 1.44 NM
It's the same torque on the other arm so using..
Force = Torque/Distance
= 1.44NM / 0.5M
= 2.88N
Have a go at Q2. May help to add the 2.88N force to the diagram.
CWatters said:
Correct.
= 1.2N * 1.2M
= 1.44 NM
= 1.44NM / 0.5M
= 2.88N
Great thank you!
How about the x and y components? How would I go about solving that? Trig?
Start with the original drawing in the link you posted and produce a free body diagram for the cranked beam.
eg Add..
a) the 2.88N force that the sensor puts on the beam.
b) arrows representing the x and y forces at the pivot.
The beam isn't accelerating (in any direction) so what does that mean for the net force on the beam (in any direction)?
PS: Remember the question says...
It is 0?
So you'll have the reaction force in the y direction?
The net force in the horizontal (or vertical) direction will be zero because F=ma so if a = 0 then F=0.
But show your working. The recommended procedure for any similar problem is to:
Make the drawing
Define which direction(s) are positive
Label the forces
Write the equations
Solve any simultaneous equations (if necessary)
Substitute values
Check answer makes sense.
PS In most exams I've sat you get marks for getting the procedure right even if you make an arithmetic somewhere near the end. If you only give the answer and it's wrong due to a trivial error you get zip.
Thank you so much! That has helped lots thank you! Yeah we get that in the UK too, could get most the marks with all the wrong answers
So in the x direction it'll be -2.88N since it'll be in the opposite direction to air flow
Correction the sign is also wrong...
Because it is transferring 2.88N of force to the sensor, so if y is 0N, then the x component must be the remaining 2.88N?
Damn. All wrong
Err that sounds all mixed up.
Back in a moment.
Here is my Free Body Diagram.
FD = Drag Force = -1.2N
FL = Lift Force = 1.75N
FS = Sensor force = 2.88N
FY = Y component of force at pivot
FX = X component of force at pivot
The drag force is to the left so that is also the direction of the airflow.
The problem says to assume:
X is "positive in the direction against the airflow" so +ve is to the right.
Y is "positive in the upward direction"
Have a look and then write an equation that sums all the horizontal forces to zero.
I don't know what equations they could be though?
Force of drag - x component = 0? So x component = Fd?
Great thank you!
Fy+Force lift = 0
Fy=- Force lift
Fy= -1.75N
But it should be 0?
Ah of course that's vertical as well,
I thought you said the y component was 0 as it wasn't accelerating though?
It's not the y component that's zero.
If an object isn't accelerating in any direction (including rotational acceleration) then
All the horizontal forces sum to zero
All the vertical forces sum to zero
All the rotational forces (aka torques) sum to zero
So vertically..
FY + FL + FS = 0
In some problems the forces aren't horizontal or vertical but at some angle (theta) so you have to break down those forces into horizontal and vertical components then sum them. This tends to gives you equations like..
Vertical..
F*Sin(theta) + some other forces = 0
Horizontal..
F*Cos(theta) + some other forces = 0
That has helped me so much thank you!
I understand that now, I just have trouble figuring out where to begin.
This mechanical test is really hard, I actually got 100% in the electronics one believe it or not, and I don't like electronics at all.
Would it be okay to get some of your help on other questions I find tricky?
Thanks!
Happy to help if I can but best post questions to the forum rather than me personally as I'm not always around.
PS: I have twins age 13 who have their own homework problems!
Sure, that's fine help if you're around!
Thanks! They must get good grades haha
