Work to pump water from a 22 ft circular pool with 4 ft depth
  • Thread starter Thread starter RedBarchetta
    Work
3 replies · 3K views
RedBarchetta
A circular swimming pool has a diameter of 22 ft, the sides are 5 ft high, and the depth of the water is 4 ft. How much work is required to pump all of the water over the side? (Use the fact that water weighs 62.5 lb/ft^3.)
(a) Show how to approximate the required work by a Riemann sum. Give your answer using the form below. (If you need to enter -infinity or infinity, type -INFINITY or INFINITY.)
http://www.webassign.net/www21/symImages/5/b/9d364b30bb301d2a03a8ec803e5bf6.gif
(b)Express the work as an integral and evaluate it.
I've found everything in the riemann sum equation minus the "E". What would this be?
A=N
B=infinity
C=1
D=N
E=?
One I find that, I should be able to setup the integral and solve it.
Thanks!
Do you understand what that formula MEANS? Or where it came from. Frankly, to me it makes no sense. Unless there is an x "hidden" in the E it has the wrong units: the area of a circle is [itex]\pi r^2[/itex], not [itex]\pi r[/itex]!
Imagine dividing the pool into layers- with each layer a specific depth x below the level of the water and thickness [itex]\Delta x[/itex]. That "layer" has area [itex]\pi(11^2)[/itex] square feet and so volume [itex]121\pi \Delta x[/itex] cubic feet. All the water in that "layer" has weight [itex](62.5)121\pi \Delta x[/itex] pounds and it must be raised x+ 5 feet (5 feet up to the water level and another 5 feet to the top of the pool). How much work is required to do that? The total work is found by summing over all the different "[itex]\Delta x[/itex] thickness layers. You turn that Riemann sum into an integral by taking [itex]\Delta x[/itex] smaller and smaller- becoming dx. The limits of integration will be from 0 (the top of the pond) to 4 (the bottom).
Can you come up with a mathematical expression describing the amount of work done [tex]\delta W[/tex] for each [tex]\delta V[/tex] infinitesimal volume of water to be raised from its current depth in the pool to its height?
Thanks HallsOfIvy & Defennder. Well, now I've solved the problem and found the amount of work, but the elusive "E" variable in that question escapes me. :smile:
