Working with the Saha equation in Mathematica
  • Context: Mathematica
  • Thread starter Thread starter dthomas
    Mathematica
The discussion revolves around the application of the Saha equation to calculate the ionization curve for hydrogen at a specific matter density using Mathematica. Participants explore plotting the reaction coordinate against temperature and address issues related to coding and constants in Mathematica.
  • One participant outlines the Saha equation and expresses the need to plot the reaction coordinate (x) versus temperature (t) in Mathematica.
  • Another participant suggests using either ImplicitPlot or ContourPlot depending on the version of Mathematica, and warns about reserved words in Mathematica that could cause errors.
  • A third participant shares their modified code and notes discrepancies between their plot and a textbook reference, indicating that their plot does not match expected results.
  • One participant attempts to simplify the expression derived from the Saha equation to investigate the source of discrepancies, noting that some values lead to warnings and unexpected results.
  • Another participant revises their code and reports achieving the correct shape of the curve after checking their constants and clearing previous variables, though they remain uncertain about the initial failure.
Participants do not reach a consensus on the initial discrepancies in the plots, as some suggest potential errors in coding or constants while others focus on the mathematical formulation. The discussion remains unresolved regarding the exact source of the discrepancies.
Limitations include potential errors in variable definitions, the impact of reserved words in Mathematica, and the need for careful handling of constants and units. Some participants express uncertainty about the validity of their results based on the behavior of the equations at certain temperature values.
dthomas
I am trying to calculate the ionization curve for hydrogen at a given matter density (in this case it happens to be 55 atoms/cm^3)
From the Saha equation and putting the concentrations in terms of reaction coordinates. It looks something like this:
Log[x[t]^2/(1 - x[t])] = 1/(k t)E - 3/2 Log[-(1/(k t))E] + 3/2 Log[(-2pimE)/(n^(2/3) h^2)]
k is the Boltzmann constant, h is Planck's constant, and E is a given energy value
t is Temperature
Basically I need to get Mathematica to plot the reaction coordinate (x) vs. t
If anyone has some advice as to how to do this, it would be greatly appreciated
I don't know what version you have, older versions use ImplicitPlot, newer versions use Contour plot.
"E" is reserved by Mathematica for Euler's constant and it will be very upset if you think that is a variable. Pi is reserved by Mathematica for the constant pi. Variables being multiplied either need to be separated by a space or by "*". Plotting versus x[t] will likely be a source of unending grief for you. Given all that, try something like this
In[1]:= <<Miscellaneous`PhysicalConstants`
In[2]:= k=BoltzmannConstant;
h=PlanckConstant;
e=something;
m=something;
n=something;
and either
In[3]:= <<Graphics`ImplicitPlot`
In[4]:= ImplicitPlot[Log[x^2/(1-x)]==1/(k*t)*e-3/2 Log[-(1/(k*t))*e]+3/2 Log[(-2Pi*m*e)/(n^(2/3)*h^2)],{t,something,something}]
or
In[3]:= ContourPlot[Log[x^2/(1-x)]==1/(k*t)*e-3/2 Log[-(1/(k*t))*e]+3/2 Log[(-2*Pi*m*e)/(n^(2/3)*h^2)],{x,something,something},{t,something,something}]
where you fill in all the "something"s with appropriate values and then let us know if it worked or where it failed and what kind of error messages it reported to you.
Read the help pages or Google for
Mathematica TheMathematicaReservedWordYouAreLookingFor
to find the documentation with examples and explanations.
Thanks so much for the reply it helped quite a bit. I had to tweak it a bit, so here is what I used as my code. (I am in Mathematica 7 by the way)
Clear["Global`*"]
<< PhysicalConstants`;
k = 8.617343*10^-5;(* Boltzmann constant measured in eV/K *)
h = 4.13566733*10^-15; (* Planck's constant measured in
eV s *)
energy = -13.6;
m = 1/1836;(* electron mass * proton mass/ hydrogen mass
measured in proton masses *)
n = 10^-22/1.0794;(* number density (mol H)/cm^3 *)
ContourPlot[
Log[x^2/(1 - x)] ==
1/(k*t)*energy - 3/2 Log[-(1/(k*t))*energy] +
3/2 Log[(-2*\[Pi]*m*energy)/(n^(2/3)*h^2)], {t, 1000, 4000}, {x,
0, -100}]
I am trying to verify a plot given the textbook for my course, but this gave a plot that doesn't match. I am trying to figure out how to upload the plot to this post. I couldn't use the physical constants as the equation needed everything in terms of proton masses and electron volts
http://einstein.drexel.edu/~bob/Thermodynamics/saha.pdf
I am trying to show that the curve holds true for a different matter density (assuming all matter at that density is hydrogen). The curve is on page 4 of the PDF I linked to this post. I hope that this is specific enough, thank you so much for your help
If you are entering your own constants you can eliminate the
<<PhysicalConstants'
To try to track down the discrepancy I use your constants and then
In[6]:= Simplify[1/(k*t)*energy-3/2 Log[-(1/(k*t))*energy]+3/2 Log[(-2Pi*m*energy)/(n^(2/3)*h^2)]]
Out[6]= 127.536 - 157821./t - 1.5 Log[1/t]
Now I want to see a table of {t,x} to get some idea what is going on
In[7]:= Table[{t, x /.NSolve[Log[x^2/(1-x)] == 127.536-157821./t-1.5` Log[1/t], x]}, {t, 1000, 4000, 100}]
Note: some long strings of trailing digits snipped when put into this post.
Out[7]= {{1000, {-0.0000471618, 0.0000471596}},
{1100, {-0.0683075, 0.06394}},
{1200, {-776.204, 0.998713}},
{1300, {-2.16375*^7}},
{1400, {-1.41081*^11}},
{1500, x},
{1600, x},
{1700, {-8.23303*^19}},
{4000, {-4.528245*^43}}}
That isn't going to look anything like what your curves in the pdf look like. I get a stream of warnings about 1/0. Some t have two solutions, some have none, as the t gets close to 4000 the x gets close to minus infinity, not 1.
So something seems to be seriously wrong.
From this can you start to track down where the first layer of errors might be? Maybe I've made some typos you can catch. Maybe you've made some you can catch.
Perhaps once those are found and stripped away then maybe we can start to see what direction to go to be fix the next layer and start in the direction of being able to replicate the example in the text.
ContourPlot[
Log[x^2/(1 - x)] ==
3/2 Log[(-2*Pi*m*energy)/(n^(2/3)*h^2)], {t, 1, 4000}, {x, 0, 1}]
I checked my constants and starting equation again this gave me the correct shape curve. I don't know why the code didn't work the first time, but it might have had to do with not clearing whatever was in my program from before this code.
Thank you so much for the help and I appreciate the responses
