[Worksheet] Horizontal/Vertical components + other
  • Thread starter Thread starter Torald
    Components
The discussion revolves around solving a physics worksheet involving horizontal and vertical components of motion, specifically in the context of projectile motion. Key calculations include determining horizontal velocity (Hv) and vertical velocity (Vv) using trigonometric functions, where U (initial velocity) is 6.0 m/s, Hv is calculated as 6cos(50) resulting in 4.5 m/s, and Vv as 6sin(50) resulting in 3.9 m/s. The participant also addresses the time to reach a net 2.0 meters away, calculating it as 0.3 seconds using the formula t = d/v. The importance of accounting for gravity in vertical motion is emphasized.
  • Understanding of projectile motion principles
  • Familiarity with trigonometric functions (sine and cosine)
  • Basic knowledge of kinematic equations
  • Ability to perform calculations involving angles and velocities
  • Study the effects of gravity on projectile motion
  • Learn how to apply kinematic equations in two dimensions
  • Explore advanced trigonometric applications in physics
  • Practice solving projectile motion problems with varying angles and initial velocities
Students in higher physics courses, educators teaching projectile motion, and anyone looking to strengthen their understanding of trigonometric applications in physics problems.
Torald
Hey there.
Was given this sheet a while ago. Went over it in class a week ago, completely forgot everything about it today (This is a fresh sheet, lost the one I did.). Have an NAB tomorrow, and couldn't find my physics teacher today to get this worked out.
So, the problem is that I have no clue with what to do. I got some basic info down, but that is it.
Course is in Higher Physics.
Thanks in advance.
Edit : FORGOT THE WORKSHEET!
I don't understand what you wrote there.
For (a), you should consider a triangle, where one angle is 50° and the other one is 90° ("standing" on the ground). This will give a relation between horizontal speed and total speed, as well as a relation between vertical and total speed via trigonometry.
For b: Does the horizontal velocity change? If not, how can you calculate the time until the ball reaches the net?
c: What is the vertical position of the ball after that time?
Thanks for the reply.
U = Initial Velocity (6.0 m/s)
Hv = Horizontal Component (2.0m)
Vv = Vertical Component (0.9m)
Focusing on question a):
[STRIKE]Trigonometry...Egh. Hate it.
Since the Hv is perpendicular (90 degrees), to calculate the components, it would involve cos(x), right?
Don't know what do with that, though. For the Hv, would I do (As in, punt into a calculator) "6.0cos(90)"? Or "2.0cos(90)"? Or...?
As I said, I have not much of a clue as to what to do here.
Your help is most appreciated.
Edit: Alright. I think I figured out how to calculate the components.
Vv = 6sin(50) = 3.9
Hv = 6cos(50) = 4.5
But shouldn't they add up to 6? 3.9 + 4.5 = 8.4
Gah. Confuzzled.[/STRIKE]
Got it!
The Hv = Vcos(Θ)
= 6cos(50)
= 3.9
Trick to remember : HC - Horizontal Cos
The Vv = Vsine(Θ)
= 6sine(50)
= 4.5
Trick to remember : VS - Vertical Sine
For
D = 2.0
V = 6.0
So, use d=v/t |With rearranging| t = d/v
2.0/6.0 = 0.3
Although, I don't know what to do for [c]. Help would be good. I assume it involves the Vv, Velocity, time.
For c) so at 3 s it reaches the net. How far will it travel vertically in 3s with initial velocity 6sin30? If this is greater than 0.9 then it makes it over the net.
Torald said:
The Vv = Vsine(Θ)
= 6sine(50)
= 4.5
You should be careful with rounding (4.596...)
For
D = 2.0
V = 6.0
2.0/6.0 = 0.3
No, it is a horizontal distance, and the horizontal speed is not 6m/s.
@ofeyrpf: Don't forget gravity.
10K
  • · Replies 54 ·
