livinonaprayer
- 4
- 5
have you encountered it and/or solved it? what did you think?
JonnyG said:I got infinitely many solutions...anyone else get that too?
nooo don't give up! it took me 5 hours to find the solution. and you don't need complicated equations, you're only allowed to use simple geometry.Hornbein said:I figured all the easy angles, then was left with three equations and four unknowns. So I manfully gave up. I'm too dumb to do it.
i think there's only one solution? i got only one solution and after going over it multiple times i even checked online to confirm that my way of getting there was correct. remember, you're only supposed to use basic geometry, no trig or some sort of super advanced math.JonnyG said:I got infinitely many solutions...anyone else get that too?
I spent about an hour on it yesterday, and an hour today, paying careful attention to looking for a solution by means of the specific elementary geometry principles they list at the bottom. I have no idea where two parallel lines being cut by a third fits in, nor where the equilateral triangle might come into play. But, they wouldn't have presented them if they weren't relevant, so I figure once I realize in what way they can be employed here, the solution should be immanent.livinonaprayer said:nooo don't give up! it took me 5 hours to find the solution. and you don't need complicated equations, you're only allowed to use simple geometry.
they are important, just like the rest of the information given.zoobyshoe said:I spent about an hour on it yesterday, and an hour today, paying careful attention to looking for a solution by means of the specific elementary geometry principles they list at the bottom. I have no idea where two parallel lines being cut by a third fits in, nor where the equilateral triangle might come into play. But, they wouldn't have presented them if they weren't relevant, so I figure once I realize in what way they can be employed here, the solution should be immanent.
nope, but that's because i always solve geometry problems like that. the hint isn't an actual step closer to the solution, it kinda points to to a 'technique' you MUST use to find it (you can't solve it otherwise, it's kinda like trying to write a computer program without knowing part of the code language or writing style, impossible). i would check out the hint if you're not familiar with high school geometry.zoobyshoe said:I'm still too stoic to check out the hint. However, I will ask you, was the hint necessary in your case?
OK, I checked out the hint and it didn't help at all, since I'd already been doing that.livinonaprayer said:nope, but that's because i always solve geometry problems like that. the hint isn't an actual step closer to the solution, it kinda points to to a 'technique' you MUST use to find it (you can't solve it otherwise, it's kinda like trying to write a computer program without knowing part of the code language or writing style, impossible). i would check out the hint if you're not familiar with high school geometry.
ohh... so keep trying! try looking at the problem in different ways, exploring new directions. see what the already existing information has to offer. make a list of moves that you've already figured out that might be useful.zoobyshoe said:OK, I checked out the hint and it didn't help at all, since I'd already been doing that.
Oh, sheez, you know better than that, micro.micromass said:Pretty obvious if you use trig. My point of view is: any proof is a good proof, so I don't bother finding it without trig haha
I got a different answer.vin300 said:I have created a solution in pictures but seems to be impossible to upload. If the central intersection is called O, then various angles are obtained as follows: C=20, AOB=70, DOE=70, DOA=110, ADO=50, EOB=110, OEB=40, CDO=130, CEO=140. Thus far, almost every angle except x and its complement have been derived. To find x, the only possible way seems to be exactly find every elemental length. Use sine rule. AC=CB = 100. By sine rule, AB=34.729, from AB, DB=44.6475, from AB again, EB = 46.79 AB= AD, From EB, CE=53.21. Use cosine rule to find DE, as CD=100-AD= 65.271 DE found to be 23.756. Use sine rule once again with DE to obtain angle EDC nearly 50 degrees. We know the rest already, hence x= 30 degrees
are you talking about the second one? i haven't tried to solve it yet and I'm too lazy to look up high school trig right now so... as for problem 1 (the one i was talking about), x isn't 30 degrees. for both problems trig isn't allowed and you can definitely find the solution by just using simple geometry. (and please post this under a spoiler warning next time). keep trying!vin300 said:I have created a solution in pictures but seems to be impossible to upload. If the central intersection is called O, then various angles are obtained as follows: C=20, AOB=70, DOE=70, DOA=110, ADO=50, EOB=110, OEB=40, CDO=130, CEO=140. Thus far, almost every angle except x and its complement have been derived. To find x, the only possible way seems to be exactly find every elemental length. Use sine rule. AC=CB = 100. By sine rule, AB=34.729, from AB, DB=44.6475, from AB again, EB = 46.79 AB= AD, From EB, CE=53.21. Use cosine rule to find DE, as CD=100-AD= 65.271 DE found to be 23.756. Use sine rule once again with DE to obtain angle EDC nearly 50 degrees. We know the rest already, hence x= 30 degrees
Here is everything you need to know to solve the above problems.
Lines and Angles
Triangles
- When two lines intersect, opposite angles are equal and the sum of adjacent angles is 180 degrees.
- When two parallel lines are intersected by a third line, the corresponding angles of the two intersections are equal.
- The sum of the interior angles of a triangle is 180 degrees.
- An isosceles triangle has two equal sides and the two angles opposite those sides are equal.
- An equilateral triangle has all sides equal and all angles equal to 60 degrees.
- A right triangle has one angle equal to 90 degrees.
- Two triangles are called similar if they have the same angles (same shape).
- Two triangles are called congruent if they have the same angles and the same sides (same shape and size).
- SAS (Side-Angle-Side): Two triangles are congruent if two pairs of sides of the two triangles are equal, and the included angles are equal.
- SSS (Side-Side-Side): Two triangles are congruent if three pairs of sides of the two triangles are equal.
- ASA (Angle-Side-Angle): Two triangles are congruent if two pairs of angles of the two triangles are equal, and the included sides are equal.
- AAS (Angle-Angle-Side): Two triangles are congruent if two pairs of angles of the two triangles are equal, and a pair of corresponding non-included sides are equal.
- AA (Angle-Angle): Two triangles are similar if two pairs of angles of the two triangles are equal.
