Would open or flanged ball bearings be better for this application?
  • Thread starter Thread starter s09
    Application Ball
In selecting ball bearings for applications involving a gear, the choice between open and flanged ball bearings hinges on specific load requirements and mounting preferences. Open ball bearings allow for easier lubrication management but require external grease containment, while flanged ball bearings provide a more stable mounting option. It is essential to calculate both thrust (axial) and radial loads to ensure the selected bearings can support the application. SKF offers comprehensive tools for bearing selection, which should be utilized for optimal results.
  • Understanding of thrust and radial load calculations
  • Familiarity with bearing types, specifically open and flanged ball bearings
  • Knowledge of lubrication methods for ball bearings
  • Experience with mounting techniques for bearings
  • Research SKF bearing selection tools for specific applications
  • Learn about thrust and radial load calculations in bearing design
  • Explore lubrication methods for open and flanged ball bearings
  • Investigate mounting techniques for optimal bearing performance
Mechanical engineers, product designers, and anyone involved in selecting and implementing ball bearings in rotating machinery applications.
s09
Hey all, recently found this site about ball bearings and have a question:
http://www.mcmaster.com/#standard-ball-and-roller-bearings/=ecllbn
I have an application that will have a gear sit on top of the ball bearing as it spins (the weight won't be too large, don't want it to be), what would be the better options? Open ball bearings? Flanged ball bearings? Something else?
You need to work out the thrust (axial) load as well as the radial load, and find bearings that can support them. Also consider misalignment and speed. Try SKF's site, it has pretty comprehensive tools to select a bearing.
The ones with the covers can have grease retained in them. If it's open you'll need to contain the grease or oil some other way.
The flange is kind of secondary. Depends how you prefer to mount it.
  • · Replies 16 ·
  • · Replies 16 ·
