bolbteppa
- Messages
- 300
- Reaction score
- 41
vanhees71 said:There is no "assumption of no path" anywhere.
Even proponents of BM, such as slide 4 of http://www.tcm.phy.cam.ac.uk/~mdt26/PWT/lectures/bohm7.pdf , are very clearly aware that all of standard QM can be based on the claim that there are no paths (after which you need to set up things to replace CM and this is the 'positive content' of QM as Landau calls it), it literally quotes the Landau reference I keep bringing up:
..an attitude which propagated into more or less every modern textbook:
“It is clear that [the results of the double slit experiment] can in no way be reconciled with the idea that electrons move in paths.
In quantum mechanics there is no such concept as the path of a particle.” [Landau and Lifshitz]
slide 4 - http://www.tcm.phy.cam.ac.uk/~mdt26/PWT/lectures/bohm7.pdf
In BM the Schrödinger equation comes out of thin air, it's completely unjustified... In normal QM it absolutely does not come out of thin air, it is derived, either as e.g. Dirac does it, or as e.g. Landau does based on the HUP claiming no paths exist, Born, and the necessary existence of a quasi-classical limit, it's all in the Landau reference from first principles that even BM proponents reference...
The Schrödinger equation in BM is clearly just stolen from QM and at best (this is very common) hand-wavingly justified by the existence of these historical derivations as if that makes any theoretical sense or with ludicrous things like the de Broglie relation or probability conservation out of thin air - one can even understand why people would go along with BM: 'if you take X as axioms then Y happens', fine, but it's just a game unless one can face up to the immediate issues that normal QM answers so concisely in starting from 'no paths exist'... The Durr references are no basically different to all the other BM references in this respect.
Clearly if you steal an equation derived on the assumption of no paths and then end up with paths you've made such a gigantic error your 'theory' is immediately nonsense, it's so basic...
vanhees71 said:What de Broglie and later Bohm did was to use the Schrödinger equation and the resulting wave function but they reinterpreted the physical meaning of this wave function completely compared to the mainstream Copenhagen interpretation, which indeed has more problems than it pretends to solve
I am not even going after the many contradictions other people claim arise even when you take BM at face value, that's another huge discussion, my issues with BM are way more basic, the very tools it uses are completely illegitimate to even use if they do not begin by declaring that paths don't exist and this by itself immediately invalidates the whole thing.
