Write down the equation of the function corresponding to the graph
  • Topic:
  • Thread starter Thread starter mathlearn
    Function Graph
mathlearn
Data
A graph in the form of $y=(x-1)^2-6$
Problem
Write down the equation of the function corresponding to the graph obtained when the above graph is translated 1 unit in the negative direction of the $x$ axis
Workings:
Where do I need help
In writing the equation of the funtion.
Mathematics news on Phys.org
If we are given a function $f(x)$, then to translate the graph of that function $k$ units to the left, we may use $f(x+k)$.
Can you proceed?
Can you proceed?
$\displaystyle f(x)=a(x-h)^2+k$
The function is in this form.
Substituting the values,
$y=(x-1)^2-6$
k=-6
Is it $f(x-6)$? but I am not sure whether this is correct?
You are given:
$$y(x)=(x-1)^2-6$$
So, to translate this one unit to the left, use:
$$y(x+1)=((x+1)-1)^2-6=x^2-6$$
MarkFL said:
You are given:
$$y(x)=(x-1)^2-6$$
Thank you very much (Yes) , Now I see it in desmos
[graph]rqbf6pohnc[/graph]
Can you proceed?
But what I don't still understand is it's derivation.
Now what has actually happened here $$y(x+1)=((x+1)-1)^2-6=x^2-6$$;
Using $f(x+k)$ Do you plug in the values for $f,x,k$ from the given function.
What does $f$ stand for & from which part of the function was a value taken.
A comment here would be highly appreciated :)
Suppose we are given a function $f(x)$ and we wish to shift the graph of that function horizontally. If we wish to shift the function to the left $k$ units, then we can think of accomplishing this by moving our coordinate axes horizontally to the right $k$ units, that is:
$$X=x+k$$
So now what we have is that:
$$f(X)=f(x+k)$$
is the graph of $f(x)$ shifted to the left by $k$ units. Now, in this problem, we are given the function:
$$y(x)=(x-1)^2-6$$
And we are told to shift it 1 unit to the left.
So, in terms of what I posted above, we have $y=f,\,k=1$ and so there results:
$$X=x+k$$
$$f(X)=f(x+k)$$
$$y(x)=(x-1)^2-6$$
(Yes) Thank you very much again
To shift the function to the left y(x+1) and vice versa to shift the function right y(x-1)
