Writing a polynomial for this box thing
To write a polynomial representing the area of the shaded region, one must first calculate the areas of both the outside and inside boxes. The area of the shaded region can be found by subtracting the area of the inside box from the area of the outside box. A polynomial is defined as a function involving powers of the variable x, and it is important to distinguish between area and perimeter, as the area is calculated using length times width rather than the perimeter formula. Clarification on mathematical terminology is crucial for understanding and solving these types of problems. Understanding these concepts will aid in accurately modeling the area with a polynomial.
ceres_sun
Could someone guide me through this? *math dummy*
Write a polynomial in standard form that models or represents the area of the shaded region.
http://www.sfu.ca/~tca19/thing.GIF
Thanks!
What is the area of the outside box?
What is the area of the inside box?
How would you get the area of the shaded region?
|2(x-4)+2(x+3)| - |2(x+2) + 2(x+1)|
I'm actually more confused as to what a polynomial is >_> *cough*
A polynomial is a function that only involves powers of the variable x.
However, your real problem is that you are confusing "area" with "perimeter". The area of a rectangle is "length times width", lw, not 2l+ 2w. Also, since all the numbers involved are positive, there is no need for absolute value.
LOL thank you so much.
Yes, my main problem with math is that I don't know what most of the terms mean and/or confuse them with other terms...-_-
I need a math dictionary.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
