Wronskian: null space equals the span of independent functions
  • Context: Undergrad
  • Thread starter Thread starter psie
    Linear algebra
The discussion revolves around the properties of the Wronskian determinant in relation to the null space of a linear transformation defined on the space of smooth functions. Participants are attempting to prove that the null space of the transformation corresponds to the span of a set of linearly independent functions. The conversation includes elements of linear algebra, function theory, and the implications of linear independence.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant defines the Wronskian and expresses confusion about proving that if the Wronskian is zero, then the function must be a linear combination of the independent functions.
  • Another participant questions the implications if the leading coefficient in the linear combination is zero, suggesting it leads to a contradiction regarding linear independence.
  • Some participants inquire whether a differential equation is involved in the problem, while others clarify that it is an exercise from a linear algebra context.
  • There is a discussion about the need to show that coefficients in the linear combination are constants rather than functions of the variable.
  • One participant presents a counterexample with specific functions to challenge the claim about linear dependence.
  • Concerns are raised about the differentiability of certain functions at specific points, particularly regarding the nature of the functions involved.
  • Participants express confusion about the scalar domains and the nature of the functions being discussed, particularly in relation to complex and real variables.
Participants do not reach a consensus on the implications of the Wronskian being zero, with multiple competing views on the nature of the coefficients and the conditions for linear dependence. The discussion remains unresolved regarding the proof of the relationship between the null space and the span of the independent functions.
There are limitations regarding the definitions of linear independence and the scalar fields involved, as well as the assumptions about the differentiability of the functions at certain points. The discussion also highlights the complexity of the relationships between the functions and their derivatives.
psie
TL;DR
I'm working an exercise as explained below involving the Wronskian determinant. I just don't know how to show one inclusion. Any help is very appreciated.
Let ##y_1,y_2,\ldots,y_n## be linearly independent functions in ##C^\infty(\mathbb C)## and let ##y\in C^\infty(\mathbb C)##. Define the column vectors $$v(t)=(y(t),y'(t),\ldots,y^{(n)}(t))^t$$and $$v_i(t)=(y_i(t),y_i'(t),\ldots,y_i^{(n)}(t))^t\quad\text{for }1\leq i\leq n.$$ Consider the linear transformation ##\mathsf T: C^\infty(\mathbb C)\to C^\infty(\mathbb C)## defined by $$[\mathsf T(y)](t)=\det\begin{pmatrix}v(t)&v_1(t)&\cdots&v_n(t)\end{pmatrix}.$$(This determinant is called the Wronskian.) I'm trying to prove ##\mathsf N(\mathsf T)=\operatorname{span}(\{y_1,y_2,\ldots,y_n\})##. One direction is quite simple, namely ##\supseteq##. The other one, however, I don't know. Let ##y\in\mathsf N(\mathsf T)##, then ##\mathsf T(y)=0## is the zero function and consequently the determinant is zero for every ##t##. In other words, $$0=[\mathsf T(y)](t)=\det\begin{pmatrix}v(t)&v_1(t)&\cdots&v_n(t)\end{pmatrix}.$$ Now, I'm a bit confused how to conclude that ##y## is a linear combination of ##y_1,y_2,\ldots,y_n##. The above equality implies ##v(t),v_1(t),\ldots,v_n(t)## to be linearly dependent for all ##t##, so there are scalars ##\alpha_0(t),\alpha_1(t),\ldots,\alpha_n(t)##, not all equal to zero simultaneously, such that $$\alpha_0(t)v(t)+\sum_{i=1}^n\alpha_i(t)v_i(t)=0.$$ This is actually a system of linear equation and I don't know how to proceed. My guess is that somehow one wants to show that ##\alpha_0(t),\alpha_1(t),\ldots,\alpha_n(t)## are in fact constants and ##\alpha_0(t)## does not equal ##0##, but I don't know how. Appreciate any help.
What about the first component of the equation in case ##\alpha_0 \equiv 0##?
Is there a differential equation involved?
Well, I think that if ##\alpha_0(t)=0## even for some ##t##, we have a problem. Because that forces the other ##\alpha_i(t)## (##1\leq i\leq n##) to be zero simultaneously by the linear independence of ##y_1,y_2,\ldots,y_n##, right? But we said they couldn't all be zero simultaneously, contradiction. But I guess we still need to show the ##\alpha_i(t)## (##0\leq i\leq n##) are constants, or?
No. This is just an exercise I found in a linear algebra book under a chapter of determinants.
You haven't specified the domain which we use for linear (in)dependence or the term span. Either it is the complex numbers or functions. As the problem is from a linear algebra book, I assume we are talking about complex vector spaces. But whatever it is, it has to be the same ##\mathbb{F}##:
\{y_1,\ldots,y_n\} \text{ is } \mathbb{F}\text{-linear independent} \, , \,N(T)=\operatorname{span}_\mathbb{F} \{y_1,\ldots,y_n\}
We have ##\alpha_i \in \mathbb{F},## i.e. the same domain in both cases.
Ok. By ##C^\infty(\mathbb C)## I meant the subspace of ##\mathbb C^{\mathbb R}## (i.e. the vector space of complex-valued functions of a real variable). Any element in ##C^\infty(\mathbb C)## has derivatives of all orders. So ##\alpha_i## are indeed complex-valued.
What we want to show is that there are complex constants ##a_1,a_2,\ldots,a_n##, not all zero, such that $$y(t)=a_1y_1(t)+a_2y_2(t)+\cdots+a_ny_n(t),$$given ##\mathsf T(y)=0##.Currently I don't see how to obtain this.
What about ##y_1(t)=t^2## and ##y(t)=|t|t##. Here ##n=1##, and ##T(y)=0## but they are not linearly dependent.
Haven't you already done it?
psie said:
$$\alpha_0(t)v(t)+\sum_{i=1}^n\alpha_i(t)v_i(t)=0$$
is
psie said:
$$\alpha_0v(t)+\sum_{i=1}^n\alpha_iv_i(t)=0$$
if we simply forget about the variable and write ##\alpha_i\in \mathbb{F}.## But this means
psie said:
$$\alpha_0y=[\alpha_0v(t)]_0+\sum_{i=1}^n[\alpha_iv_i(t)]_0=0=\sum_{i=1}^n\alpha_i y_i$$
and ##\alpha_0\neq 0## since otherwise the ##y_i## would be linearly dependent.
Is ##y(t)\in C^{\infty}(\mathbb C)##? I'm not sure it is differentiable at ##t=0##.
Kind of. The only thing that's missing is I think that we still need to show the ##\alpha_i## are constants, not functions of ##t##.
It is real differentiable. The factor ##t## does this. Not sure, whether it is complex differentiable.
The question refers to the part of your proof that you called simple and did not show.
They never were functions of ##t.## Everything happens in ##\mathbb{C}^\infty .## Once you specify the scalar domain you have to stick with it.
I don't understand. Let ##y\in\mathsf N(\mathsf T)##, then ##\mathsf T(y)=0## is the zero function and consequently the determinant is zero for every ##t##. In other words, $$0=[\mathsf T(y)](t)=\det\begin{pmatrix}v(t)&v_1(t)&\cdots&v_n(t)\end{pmatrix}\quad\forall t\in\mathbb R.$$So for ##t=2## we get a certain matrix with complex entries and the columns are linearly dependent and sum in a nontrivial way to the zero vector. However, for ##t=3##, we may get an entirely different matrix and I don't see how one can expect the ##\alpha_i## to be the same for ##t=2## and ##t=3##. Does that make sense?
Yes, it is. The function is ##t^2## for positive ##t##, and ##-t^2## for negative.
fresh_42 said:
It is real differentiable. The factor t does this. Not sure, whether it is complex differentiable.
Wait! Isn't ##t## real? I thought that these are complex valued functions on a real variable.
I am currently completely confused. We have complex scalars (vector space), linear equations with functions as coefficients (algebra or ring), and the usually real variable ##t## as a parameterization (flows). This problem statement switches scalar domains faster than I can keep track of it.
fresh_42 said:
I am currently completely confused. We have ##\mathbb{C}## as scalars, linear equations with functions as coefficients, and the usually real variable ##t## as a parameterization. This problem statement switches scalar domains faster than I can keep track of it.
I think all functions are of the form ##f:\mathbb R \rightarrow\mathbb C##.
By the way which book is it?
fresh_42 said:
I am currently completely confused. We have complex scalars, linear equations with functions as coefficients, and the usually real variable ##t## as a parameterization. This problem statement switches scalar domains faster than I can keep track of it.
Yes, all functions are of the form ##\mathbb R\to\mathbb C##. But the problem is about a determinant of a matrix which depends on ##t\in\mathbb R##. If the columns of this matrix are linearly dependent, isn't it natural to expect that these columns sum to ##0## in a nontrivial way with coefficients depending also on ##t##?
Linear Algebra by Friedberg et al. (4th edition, page 231, exercise 28).
Ok, these are the vectors. But what in the world are the scalars? We shouldn't change them and have one ##\mathbb{F}## for all linear terms:
  • ##\mathbb{F}##-vector space ##\mathbb{C}^\infty ##
  • ##\mathbb{F}##-linearity ##\alpha_i\in \mathbb{F}##
  • ##\mathbb{F}##-transformation ##T##
  • ##\mathbb{F}##-span ##\operatorname{span}_\mathbb{F}##
  • ##\mathbb{F}##-determinant ##\det_\mathbb{F}##
  • ##\mathbb{F}##-differentials ##\dfrac{d}{dt}##
So whatever ##\mathbb{F}## is, it should be the same everywhere.
It doesn't say complex valued. I think it is not important so we can assume that the functions are real valued.
... which brings us back to your example.
Well, they use the notation ##\mathsf C^\infty## in the exercise, which they defined previously (page 130) to be the subspace of ##\mathbb C^{\mathbb R}## with derivatives of all orders.
Here's the exercise, word for word:
28. Let ##y_1,y_2,\ldots,y_n## be linearly independent functions in ##\mathsf C^\infty##. For each ##y\in\mathsf C^\infty##, define ##\mathsf T(y)\in\mathsf C^\infty## by $$[\mathsf T(y)](t)=\det\begin{pmatrix}y(t)&y_1(t)&y_2(t)&\cdots&y_n(t)\\ y'(t)&y_1'(t)&y_2'(t)&\cdots&y_n'(t) \\ \vdots&\vdots&\vdots&&\vdots\\ y^{(n)}(t)&y_1(t)&y_2^{(n)}(t)&\cdots&y_n^{(n)}(t)\end{pmatrix}.$$ The preceeding determinant is called the Wronskian of ##y,y_1,\ldots,y_n.##
(a) Prove that ##\mathsf T:\mathsf C^\infty\to\mathsf C^\infty## is a linear transformation.
(b) Prove that ##\mathsf N(\mathsf T)=\operatorname{span}(\{y_1,y_2,\ldots,y_n\})##.
I now suspect the equality in (b) is a typo and should simply be ##\supseteq##.
But it is not infinitely differentiable.
But does your proof need this distinction? What if ##n=1##?
I am not sure anymore. But I am pretty sure it is a typo in the exercise. 🙂 Thanks for the help though.
The version of the book I have found, probably breaching copyright laws, claims that
\operatorname{span}\{y_1,\ldots,y_n\}\subseteq N(T)=\left\{y\in C^\infty \,|\,T(y)\equiv 0\right\}.
So ##y=\sum_{k=1}^n a_ky_k## results in a linearly dependent first column in
T(y)=\begin{pmatrix}
y&y_1&\ldots&y_n\\
y'&y'_1&\ldots&y'_n\\
\vdots&\vdots&\ldots&\vdots\\
y^{(n)}&y^{(n)}_1&\ldots&y^{(n)}_n\\
\end{pmatrix}
so ##\det T(y)=0.## All it takes is linearity of ##T## which is more or less obvious.
