∫∫ x^2 dA ; bounded by ellipse
  • Thread starter Thread starter red6290
    Bounded Ellipse
6 replies · 10K views · last reply
red6290
try ∫∫G x^2 dA ;value is the region bounded by the ellipse 9x^2+4y^2=36
i think i have to change the variables to polar coordinate or U,V function but i have no idea.
Try 3x = r cos(theta), and 2y = r cos(theta), with r=[0,6] and theta=[0,2pi]... It might work.
∫∫ x^2 dA ; bounded by ellipse; which soln is right?
the problem is:
try ∫∫ x^2 dA ; bounded by ellipse 9x^2+4y^2=36
and i tried 2 different ways but i don't know which one is right.
first method: polar coordinate conversion.
3x= r cos (theta), 2y = r sin (theata) 0 < r < 6 , 0 < theta < 2 pi
so ∫∫ r^2 (cos(theta))^2 r dr d(theta)
= 36 pi
second method: u,v variable change
9x^2+4y^2 = 36 -> x^2/4 + y^2/9 = 1
u = x/2 , v = y/3
(-1 < u < 1, -1 < v < 1) ( I am not sure about this range. is this right?, if not what is wrong with this?)
so x= 2u
∫∫ x^2 dA = ∫∫ 4 u^2 (Jacobian=6) ds = ∫∫ 24 u^2 du dv= 32
36 pi vs. 32 ; which is right?
thank you for the answer but i have another problem.
= 36 pi
u = x/2 , v = y/3
so x= 2u
u = x/2 , v = y/3
so x= 2u
∫∫ x^2 dA = ∫∫ 4 u^2 (Jacobian=6) ds = ∫∫ 24 u^2 du dv= 3236 pi vs. 32 ; which is right?
Your range is not correct. The ellipse in the x-y plane is a circle in the u-v plane. The range -1 to 1 for u and v describes a square in the u-v plane. To really describe the circle one of the limits needs to depend on the other variable. For example, noting that the integrand u^2 is invariant if we shift the angle by pi, we can just do the integral over the top half of the circle and double the result. So, if u runs from -1 to 1, you need an integral in v that runs from zero up to [itex]\sqrt{1-u^2}[/itex]. i.e.,
[tex]2\int_{-1}^1 du u \int_{0}^{\sqrt{1-u^2}}dv[/tex]
The resulting integral in u will require you to make a trigonometric substitution.
= 36 pi
This method is almost correct. You forgot to compute the Jacobian. It's not simply [itex]dxdy = r dr d\theta[/itex]. There's an extra factor of 1/6 that comes out in the Jacobian because you have an ellipse instead of just a circle. The proper answer is [itex]6\pi[/itex].
Mute said:
Your range is not correct. The ellipse in the x-y plane is a circle in the u-v plane. The range -i to 1 for u and v describes a square in the u-v plane. So, this method is not correct.
thank you very much it was really helpful!
