Y-Delta conversion for Capacitors
  • Thread starter Thread starter cupid.callin
    Capacitors
The discussion revolves around the Y-Delta conversion for capacitors, exploring the application of this concept in circuit analysis. Participants are examining the differences in combining capacitors compared to resistors and how to calculate equivalent impedances.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of Y-Delta transformations for capacitors, questioning the validity of applying resistor equations to capacitors. There are inquiries about how to find the impedance of a capacitor and the correct equations for Y and Delta forms.
Some participants have provided guidance on converting capacitances to their equivalent impedances and shared formulas for Y-Delta transformations. There is an ongoing exploration of the implications of these transformations and the relationships between the different forms.
Participants note the differences in how capacitors combine in series and parallel compared to resistors, which influences their approach to the problem. There is also mention of the need for frequency in impedance calculations, although it is suggested that it may not be necessary for the algebra involved in the transformations.
cupid.callin
This was a ques in my book ... (Pic)
After thinking a while, i realized that it can be solved using Y-Delta (by converting Y to delta form) conversion. But i couldn't get the answer ... i don't know why ...
I used this http://en.wikipedia.org/wiki/Y-%CE%94_transform"
It is given for resistors ... i guess its same for resistors and capacitors ... Right?
Please tell me if the eqn used is wrong or something else!
Remember how capacitors combined differently in series and parallel than do resistors?
What you can do is convert all your capacitances to their equivalent impedance, then use those formulae. Impedances mix and match like resistances.
How do i find impedance of a capacitor?
[tex]Zc = 1/(j\omega C[/tex])
[tex]\omega[/tex] is the operating frequency. The result is in Ohms, and will be an imaginary value.
Don't panic! You don't need to know the frequency for the math to work out; it's a constant for the given Y to Delta situation. If you do the algebra, a pretty simple result obtains. If the resistor version is:
Ra = (R1*R2 + R2*R3 + R3*R1)/R2
Rb = (R1*R2 + R2*R3 + R3*R1)/R3
Rc = (R1*R2 + R2*R3 + R3*R1)/R1
Then the capacitor version looks like:
Ca = C1*C3/(C1 + C2 + C3)
Cb = C1*C2/(C1 + C2 + C3)
Cc = C2*C3/(C1 + C2 + C3)
And to find Y form,
C1 = (CaCb + CbCc + CcCa) / Cc
Right?
Thanks for the help gneill !
Thanks a lot !
cupid.callin said:
And to find Y form,
Right?
Thanks a lot !
Right.
You're welcome.
gneill said:
... for the given Y to Delta situation. If you do the algebra, a pretty simple result obtains. If the resistor version is:
The three capacitors enclosed in red form a Y. So does the other set of 1, 3, and 4 μF capacitors. Converting each of these sets to Δ configuration, as shown by gneill above, will allow you analyze the circuit as a combination of parallel and series capacitors.
Thanks for the help!
Is there a simple result for delta to Y as well?
Sure. Just substitute the appropriate capacitor impedances into the formulas for resistance, stir and serve. Note that a capacitor impedance is of the form [itex]1/(j \omega C)[/itex].
So for example, given that for resistors
[tex]R_1 = \frac{R_a R_b}{R_a + R_b + R_c}[/tex]
then
[tex]\frac{1}{C_1} = \frac{C_c}{C_b C_c + C_a C_c + C_a C_b}[/tex]
and so on.
EDIT: Fixed up the expression. Should have been 1/C1 on the LHS.
Thank you! :)
9K
