Zero as an element of an eigenvector
The discussion focuses on the conditions under which zero can appear as an element of an eigenvector. It highlights that if zero is the last element of the eigenvector, the matrix can be partitioned, leading to two key equations: Ax = λx and v^T x = 0. The last column of the original matrix does not influence these equations, suggesting that certain matrix properties might allow for zero in the eigenvector. Participants inquire about methods to ascertain the presence of zero in eigenvectors without explicit calculation. Overall, the conversation emphasizes the relationship between matrix structure and eigenvector characteristics.
ekkilop
Quick question on eigenvectors;
Are there any general properties of a matrix that guarantee that a zero will or will not appear as an element in an eigenvector?
Thank you!
Suppose the zero is the last element of the eigenvector. Then you can partition the matrix and write
##\begin{bmatrix} A & u \\ v^T & s \end{bmatrix}\begin{bmatrix} x \\ 0 \end{bmatrix} = \lambda
\begin{bmatrix} x \\ 0 \end{bmatrix}## where ##u## and ##v## are vectors and ##s## is a single matrix element.
Multiplying out you get the two equations ##Ax = \lambda x## and ##v^t x = 0##. Interestingly, the last column of the original matrix doesn't appear in those equations.
Thank you for your reply!
Is there a way to determine from the matrix whether a zero will appear without calculating the eigenvector explicitly?
Thread 'How to define a vector field?'
Hello! In one book I saw that function ##V## of 3 variables ##V_x, V_y, V_z## (vector field in 3D) can be decomposed in a Taylor series without higher-order terms (partial derivative of second power and higher) at point ##(0,0,0)## such way: I think so: higher-order terms can be neglected because partial derivative of second power and higher are equal to 0. Is this true? And how to define vector field correctly for this case? (In the book I found nothing and my attempt was wrong...
  • · Replies 33 ·
