Zhumell Z12 vs Meade Light Bridge 10
  • Context: Stargazing
  • Thread starter Thread starter CowedbyWisdom
    Bridge Light
The discussion revolves around the comparison of two telescopes: the Zhumell Z12 and the Meade Light Bridge 10. Participants explore aspects such as optical quality, aperture size, and suitability for different types of astronomical viewing. The conversation includes considerations of theoretical performance, practical usage, and personal experiences with telescopes.
  • Jack expresses interest in purchasing either the Zhumell Z12 or the Meade Light Bridge 10, highlighting a quality versus aperture debate.
  • Some participants suggest that the optical quality may be improved by upgrading components like the diagonal or focuser in the existing telescope.
  • There is a discussion about the advantages of larger apertures (10-12 inches) providing brighter views of celestial objects compared to smaller refractors.
  • Dave mentions that faster optics (like f5) can suffer from spherical and chromatic aberration, which may affect viewing quality at higher magnifications.
  • Participants discuss the maximum usable magnification for both telescopes, with skepticism about manufacturer claims and personal experiences suggesting lower practical limits.
  • There is a debate about the relationship between focal ratio and brightness of views, with some arguing that at the same magnification, brightness should be equivalent, while others assert that wider fields of view in faster scopes allow for more light capture.
  • Some participants share personal experiences with different types of telescopes, noting the benefits and drawbacks of each design.
Participants do not reach a consensus on which telescope is superior, as multiple competing views remain regarding the importance of optical quality versus aperture size, and the implications of focal ratios on viewing experience.
Discussions include assumptions about optical performance, the impact of different eyepiece designs, and the specific use cases for astrophotography versus visual observation. Limitations in personal experiences and anecdotal evidence are noted without resolution.
Astronomy enthusiasts considering a new telescope, particularly those weighing the benefits of aperture size against optical quality in Dobsonian designs.
CowedbyWisdom
Hey guys! I am interested in buying another telescope and was wondering if any of you had any advice about either of the two I'm split between. It seems to simply come down to a quality? vs aperture argument. The first scope is a Zhumell Z12 with a 12 inch aperture seen here... http://www.telescopes.com/telescopes/dobsonian-telescopes/zhumellz12deluxedobsonianreflectortelescope.cfm or a smaller but from what I have read online (hence the apprehension) a more quality scope in the Meade Light Bridge 10 inch dob shown here... http://www.telescopes.com/telescopes/dobsonian-telescopes/meadelightbridge10inchtrusstubedobsoniandeluxe2.cfm
Any and all advice on which would be the better choice as a 2nd telescope would be greatly appreciated. Cheers!
-Jack
Astronomy news on Phys.org
That telescope would be very similar to what you already have. What bump in quality do you seek? If you are mainly concerned with the optical quality, I would consider replacing the diagonal with [/PLAIN] this one. If the focuser isn't up to snuff... replace it too! Maybe have the main mirror refigured and recoated eventually?
not really
the scope he bought some time ago was a 90mm (f10) refractor
I had to go searching through this thread to discover for myself lol
CowedbyWisdom said:
Hey ya'll. I just ordered up this telescope and am waiting for it to come in the mail now.
http://www.telescope.com/Telescopes/Refractor-Telescopes/Refractor-Telescopes-with-Equatorial-Mounts/Orion-AstroView-90mm-Equatorial-Refractor-Telescope/pc/1/c/10/sc/335/p/9024.uts
What do you guys think? Any good? I thought 90mm was pretty big for a refractor. What do you think i'll be able to see best with this?
Both these 2 scopes being decided between will make awesome "light buckets" :)
10 - 12 inch at ~ f5 or so will be quite fast optics compared to the refractor and
nebulae etc will appear so much brighter
CowedbyWisdom ... I can assume by your trend in choices of scopes that you are not really interested in goto ability or motorised tracking for astrophotography use ?
either of these 2 dobo's will make great viewing of the skies ... see if you can find some independent/unbiased reviews of both of them ... ie. not reviews that may be posted on the sales page sites
I own a 10inch f5 dobo, solid not truss tube, if you got the truss tube one, you would need the shroud to wrap around it to keep ambient light out
I also own a Celestron C9.25, 9.25inch f10,
each has its uses the f5 is a light bucket, but lower magnification
fast optics like f5's can suffer from a little spherical and chromatic aboration but this is normally only visible around the outter edges of the field of view and under higher magnifications. They are great for wider field objects, globular and open clusters, diffuse nebulae etc
The f10 scope offers much higher useable magnification and get great for small bright objects
planetary nebulae, galaxies, planets etc
Both those scopes say max useable mag of ~ 500x. I suspect that would be really pushing it and a bit of sales hype, In practice I would suggest that ~ 200 - 300x would be closer to the truth before the aborations spoken of earlier become quite obvious
Thats from personal experience with several fast scopes over the years
Dave
http://www.telescope.com/Telescopes/...335/p/9024.uts
DOH! I even chimed in on that one!
Dave, other than the obvious effect the focal length has on magnification and eyepiece choice, why would the faster scope give brighter views? Or is that all you meant?
for the same reason a low f stop gives more light through a camera lens
f2 more light ( brighter image) than f5, than f10 than f22 etc
this is a function of the mirror, lens itself
this really becomes a benefit when doing astro photography because for a f5 you don't need to do the same much longer exposure time that you would need to do with a f10
Dave
Dave
For AP sure, but for visual use, if the magnification through the eyepiece is the same between two scopes, nothing is different, correct?
personal experience tells me that I can see a difference, say M42, the Orion Nebula
maybe will have to have both scopes outside together again one nite
just to confirm or deny my long held beliefs haha
D
I think part of the thing is... even at the same magnification,
the f5 system is going to give a wider FOV which even on its own
is letting more light through
D
D
That doesn't make sense to me man. At the same magnification the object should appear exactly the same brightness in both scopes. The difference in FOV would only be because of the eyepiece design. And I'm not sure what additional light you are referring to. An F/4 newt and an F/8 newt with equal objectives have exactly the same light gathering ability. You just need to use different eyepieces to get the same magnification on each one.
davenn said:
not really
Dave
Thanks for the response. To answer your question, I don't find the goto scopes necessary or fun. I like doing my own star finding and am not interested in astrophotography. Since I doubt there is anyway to upgrade my little refractor to make it up to snuff with a 10 or 12 inch dob (?) I felt might as well get a bigger scope. I'm also considering getting a Smith Cassegrain of some sort any suggestions are welcome. My budget is 700 dollars or less. I will be using the scope for looking at mainly the planets and galaxies.
You mite get a new 6" schmitt-cass for up to that price, maybe an 8" but I doubt it
have a good look through scope sales sites, a non-goto 8" may well be affordable
you should/mite be able to get a good respectable condition second hand one for ~$700
my 9.25" goto schmitt-cass was $3300
My 10" dobo was $600
look, if you are not worried about astrophotography, just stick with a good decent sized dobo
either of those 2 above would do you well for a few years, till "aperture fever" starts to bite hard ;) haha
cheers
Dave
  • · Replies 36 ·
  • · Replies 34 ·
14K
