What happens when Be(OH)2 reacts with acids and alkalies?
The reaction of beryllium hydroxide (Be(OH)2) with hydrochloric acid (HCl) in water produces beryllium tetrachloride hydroxide (Be(OH)4Cl) without releasing hydrogen gas. This behavior is characteristic of Be(OH)2, which acts similarly to a simple hydroxide. Additionally, when Be(OH)2 reacts with alkalies, it forms beryllates, analogous to the formation of zincates and aluminates. The stability of these compounds varies based on hydration levels and crystallization processes.
  • Understanding of acid-base reactions, specifically involving hydroxides.
  • Familiarity with the concepts of oxidation states and redox reactions.
  • Knowledge of coordination chemistry, particularly regarding metal hydroxides and their derivatives.
  • Basic principles of crystallization and water of hydration in salts.
  • Research the properties and reactions of beryllium hydroxide (Be(OH)2) in detail.
  • Study the formation and characteristics of beryllates and their comparison to zincates and aluminates.
  • Explore the concept of water of crystallization and its implications in inorganic chemistry.
  • Investigate the oxidation states of beryllium and its compounds in various chemical reactions.
Chemistry students, inorganic chemists, and professionals working with metal hydroxides and their reactions in aqueous solutions.
Vriska
what just happened? if i did this in water could i do something like Zn + H2O > Zn2+ + 2OH- + H2 so you get ZnOH2 which gets another 2 OH added from NaOH to give Na2Zn(OH)4 nowwww... somehow this is dehydrated twice.. how? why? why is this less stable than the oxide?
Chemistry news on Phys.org
Formulas of zincates and aluminates (and some other similar salts) are not well defined and depend on whether we talk about the solution or dried out salt (and how well dried out).
ah so we're alright with the hydroxide? it's not .H2O though which is what id think when we talk about drying.
also : how does Be(OH)2 react with HCl +H2O, it gives Be(OH)4Cl and no hydrogen gas. I'm having trouble understanding what's going on here
If hydrogen is deoxidized (from oxidation state +1 to ±0) something else must be oxidized. In case of your first example it is Zn (from ±0 to +2) but Be(OH)2 is no reducting agent.
You may also see the so-called water of hydration or water of crystallization - what borek mentioned above. When salts crystallize they may retain "extra" water inside the crystal. When I learned this many years ago, water of hydration was defined as water found inside the crystalline framework of a metal salt, which is not directly bonded to the metal cation. You will see it written like this ##ZnCl_2 \cdot 4H_2O##
Edit: see - https://en.wikipedia.org/wiki/Water_of_crystallization
but in BeOH4Cl Be has oxidation number as +5?
No, Be has no +5 ON, never. Even fully ionized it can be +4 at most (compare its atomic number).
Be(OH)2 reacting with hydrochloric acid behaves like a simple hydroxide.
When reacting with alkalies it can produce beryllates, similar (when it comes to problems with the formula) to zincates and alluminates mentioned earlier. Other than that there is nothing unusual with these compounds, Be is always +2 in them.
  • · Replies 17 ·
