ZnO characterisation under constant current
  • Context: Graduate
  • Thread starter Thread starter chpolyz
    Constant Current
The discussion focuses on the characterization of ZnO (zinc oxide) as a semiconductor under constant current conditions. The user observed an unexpected decrease in measured voltage after an initial rise when applying a low-level constant current, which they hypothesized might be due to electrolysis effects. However, they dismissed this possibility, indicating that the sample is a thin film and that the measurement setup involved four probes—two for current and two for voltage. The phenomenon observed, including the voltage sign change, requires further investigation into the electrochemical behavior of ZnO under these conditions.
  • Understanding of semiconductor physics, specifically ZnO properties
  • Familiarity with electrochemical measurement techniques
  • Knowledge of voltage-current characteristics in thin films
  • Experience with four-probe measurement methods
  • Research the electrochemical properties of ZnO thin films
  • Investigate transient response analysis in semiconductor measurements
  • Learn about the effects of oxygen vacancy concentration on ZnO conductivity
  • Explore advanced four-probe measurement techniques for accurate voltage readings
This discussion is beneficial for materials scientists, semiconductor researchers, and electrical engineers focusing on the characterization and application of ZnO in electronic devices.
chpolyz
As ZnO is a semiconductor with a typical resistivity of ρ ~ 10^5 Ωcm, I tried to find the settling time during measurements.
If I impose a low-level constant current (as a source), I expect a transient phenomenon (of few tens of seconds) and then a constant state while measuring Voltage to time.
Yet, what I see is a decrease in the measured voltage after its expected rise. Could somebody explain why a fall in Voltage happens and the change of its sign (from positive to negative and vice versa later on, like in the V-t plot)?
I'm guessing that you're separating the oxygen out through electrolysis.
My sample is a thin film. I do not thing it has to do with electrolysis. I used 2 probes for the current and 2 other for voltage measurement. All of them on the periphery of the sample.
  • · Replies 16 ·
10K
11K
