Testing Signals Above Threshold Voltage Non-Programmable
The discussion revolves around designing a non-programmable circuit to test whether two signals exceed specific threshold voltages for a duration of 0.5 seconds. Participants explore various circuit designs and components, including op-amps, 555 timers, flip-flops, and counters, to achieve this goal.
  • One participant suggests using an AND gate to combine the two signals and feed the output into a timing circuit, though they express uncertainty about the design of the timing circuit.
  • Another participant proposes using a pair of op-amps to detect threshold levels, with a monostable 555 timer to manage timing, indicating that the output would depend on both signals being above their thresholds.
  • Several participants inquire about the nature of the signals (audio, RF, digital) to provide more tailored suggestions, indicating that the type of signal may influence the circuit design.
  • A different approach involves using a flip-flop to capture the output of a 555 timer, suggesting that the timer could be reset if the input drops before timing out.
  • One participant recommends a 4-bit counter with a 32 Hz oscillator to hold a count until the condition is met, proposing a method to delay the output signal by a specific count.
  • Another suggestion includes using a Schmitt trigger pulse generator circuit to detect leading and falling edges of the signals, with a delay mechanism to time the outputs appropriately.
Participants express various ideas and approaches, but there is no consensus on a single solution. Multiple competing views and methods remain under consideration.
Participants have not provided specific details about the types of signals involved, which may affect the proposed solutions. There are also unresolved aspects regarding the timing circuit design and the interaction between different components.
Electronics enthusiasts, engineers, and students interested in circuit design, particularly in timing and signal processing applications.
jkm89
Greetings,
I have two signals, I need a way of testing whether they go above certain threshold voltages for a period of 0.5 seconds. This must be non programmable. I am a bit stumped o how to do it.
I thought of having these signals go into an AND gate and then have that AND gate feed into a timing circuit somehow, but I don't really know how I would design such a timing circuit.
The 555 timer will not work because I need to start the timer, then have it wait, then send a logical high if and when the two signals have been above their threshold voltages.
I have not given much thought yet, but the entry could be a pair of op-amps, to detect the above or under threshold, a 555 as a monostable: the above thresh triggers the impulse, the below thresh resets it. A second 555 is started at the same time and after 0.5s, both results are AND'd. If the first one was stopped, the result would be "0".
I will look into this later today if someone else hasn't given a schematic.
jkm89
welcome to PF :)
it mite really help if you told us all what sort of signals they are ??
give us all the information on what you are trying to do
its pretty impossible for people to give you a good answer without the background
are they audio ? RF ? maybe digital signals
Dave
maybe DTMF.
Would have thought the 555 ideal. Feed an input trigger into the timer to start it off. If output is high and input drops reset timer. If timer times out the falling edge of the output clocks the high input signal into an edge-triggered flip-flop ('74). The flip-flop output will go high only if the timer times out. You can turn this f/f output level into a pulse using another 555 that resets the f/f. For a very fast pulse you might even be able to have the f/f reset itself. Might be a starting point.
Might try a 4 bit counter with a 32 Hz oscillator. By running your anded signal into the clear pin of a 74HC193, you could hold its count at 0 until your condition was met. Then, the counter would wait 16 counts before dropping the carry output. This would be .5 to .53 seconds later.
Another method would be to use an NE555 as a simple level detector. Tie the trigger and threshold lines together with a timing capacitor and a pull up resistor to Vcc. NAND your two signals and use the result to drive an NPN transistor to discharge the capacitor. When your condition is met, the NPN transistor will turn off and allow the capacitor to charge. Upon reaching 2/3's of the supply voltage, the output of the 555 will go high.
Look into Schmitt trigger pulse generator circuits. there's plenty of examples to generate your pulse. Have one gate to detect the leading edge. One gate to detect falling edge. Latch those two momentary signal and compare later.
I' m on my phone atm but can assist in the rising edge/ falling edge method. There are other ways as well. Depends on your needs.
Edit. I re read the above forgot to say delay the lead edge gate output to an RC Delay of 500 ms and use that to time the slowed down lead edge with the falling edge with another AND gate
  • · Replies 42 ·
  • · Replies 47 ·
  • · Replies 32 ·
  • · Replies 18 ·
