Chain Rule/Product Rule Question
  • Thread starter Thread starter Mattara
    Chain
The discussion focuses on the application of the Chain Rule and Product Rule in deriving the function f(x) = (6 - x²) e^(2x) and finding the values of x where f'(x) = 0. The correct derivative is obtained by applying both rules, specifically using the Chain Rule for e^(2x). The final derivative simplifies to e^(2x)(12 - 2x² - 2x) = 0, leading to the equation 12 - 2x² - 2x = 0 for solving x.
  • Understanding of the Product Rule in calculus
  • Knowledge of the Chain Rule in calculus
  • Familiarity with exponential functions, specifically e^(x)
  • Ability to solve quadratic equations
  • Practice applying the Chain Rule with different exponential functions
  • Explore more complex applications of the Product Rule in multivariable calculus
  • Learn how to solve quadratic equations using the quadratic formula
  • Review differentiation techniques for composite functions
Students studying calculus, mathematics educators, and anyone looking to strengthen their understanding of differentiation techniques involving exponential functions.
Mattara
I am suppose to derive the following and then find x if f´(x)= 0
f(x) = (6-x2) [tex]\bullet[/tex] e2x
Which one should be used? I guess I am confused with the fact that it is e2x
Product rule gives:
(6-x2) [tex]\bullet[/tex] e2x + e2x [tex]\bullet[/tex] (-2x)
e2x(6-x2-2x) (x1 = 0)
-x2-2x+6 = 0 gives decimal values that doesn't seem to fit.
Chain rule gives:
I'm not even sure how to start here. I assume that the outer derivate is e2x? Or should the chain rule be applied to it and then the product rule?
Some kind of hint as to what is the correct path would be greatly appreciated :smile:
Edit: Latex mishap >_>
I assume that the big, big dot in your post is the multiple sign.
You can use both rules (i.e, Chain Rule, and Product Rule) in this problem. There's no limit of the number of the rules you can use. So, just use it where you think is appropriated.
f(x) = (6 - x2) e2x
f'(x) = (6 - x2)' e2x + (6 - x2) (e2x)' = ...
You have taken the derivative of e2x with respect to x incorrectly.
We should use the Chain Rule there. By letting u = 2x, we have:
[tex]\frac{d}{dx} e ^ {2x} = \frac{d (e ^ u)}{du} \times \frac{du}{dx} = \frac{d(e ^ u)}{du} \times \frac{d(2x)}{dx} = ...[/tex]
So, can you see where your mistake is?
Can you go from here? :)
Of course.
The inner is 2.
2e2x(6-x2)+ e2x(-2x)
e2x(12-2x2)+ e2x(-2x)
12-2x2-2x = 0
and there we have the values of x.
Thank you VietDao29, you were very helpful :smile:
  • · Replies 18 ·
