Equivalent Resistance in battery
The discussion revolves around calculating the equivalent resistance of a circuit involving five 5.00 Ω resistors, specifically between points F and H, and between points F and G. Participants are exploring the configurations of resistors in series and parallel.
  • Mixed
  • Participants discuss the arrangement of resistors, with some identifying series and parallel combinations. There are attempts to clarify the connections between resistors, particularly how R1, R2, R3, R4, and R5 interact in the circuit. Questions arise regarding the correct interpretation of the circuit diagram and the implications of resistor connections on the equivalent resistance calculations.
Some participants have provided insights into the resistor combinations, leading to a numerical answer for part (b). However, there remains uncertainty about the physical reasoning behind the connections, with multiple interpretations being explored. The discussion is ongoing, with participants questioning the clarity of the problem statement and the circuit diagram.
There is mention of potential ambiguity in the circuit diagram, which may affect the understanding of how resistors are connected. Some participants express concern that the problem may not be clearly worded, leading to confusion about the connections between resistors.
mbrmbrg
Figure 27-33 (attatched) shows five 5.00 [tex]\Omega[/tex] resistors. (Hint: For each pair of points, imagine that a battery is connected across the pair.)
(a) Find the equivalent resistance between points F and H.
(b) Find the equivalent resistance between points F and G.
For resistors in parallel:
[tex]R_{eq}=(\sum \frac{1}{R_i})^{-1}[/tex]
For resistors in series:
[tex]R_{eq}=\Sigma R_i[/tex]
I solved part (a) by realizing that Resistors 1 and 2 are in series, Resistors 4 and 5 are in series, and both pairs are simultaneously in parallel with Resistor 3.
Thus:
[tex]R_{eq}=(\frac{1}{R+R}+\frac{1}{R+R}+\frac{1}{R})^{-1}[/tex]
[tex]R_{eq}=(\frac{1}{10}+\frac{1}{10}+\frac{1}{5})^{-1}=2.5[/tex]
So far, so good.
But for part (b), I can't come up with the correct combination. I said that Resistors 3 and 5 are in series, and they are in parallel with resistor 4. Resistors 1 and 2 are in series, but I don't see how they fit in with the rest of the circuit. I tried treating them as parallel to Resistors 3&5 and Resistor 4, and got 2.5 Ohm (wrong answer). I tried treating them as in series with Resistors 3&5 and then set all four of those resistors parallel to Resistor 4, and got 4 Ohm (still wrong).
Looking at it again, I just get more confused, because 1&2 join the circuit IN THE MIDDLE of the 3&5 series.
:confused:
The series combination R1+R2 is in parallel with R3, and that parallel combination is in series with R5. *That* series combination is in parallel with R4.
Thank you very much, that gets the right answer of 3.125 Ohm!
Do you know of a way to figure that out with as little spatial reasoning as possible? (I was the student who could do nearly everything in geometry except see the corresponding angles without turning either my head or the diagram.)
one way is to imagine where the current is going. the shortest route from F-G is direct via R4. another path is R3+R5, which are in series and together, are parallel to R4. next, R1+R2 is parallel to R3, so we revise our calculations for R3+R5.
Hey, Zuku.
I looked at Marcusl's (wonderful!) explenation and translated it into equations.
Must work step by step. I'm not sure how to translate this symbolically; I'll try this, and you'll tell me if it makes any sense at all.
[tex]R_{eq}=R_1+R_2[/tex]
[tex]R_{eq}=((R_1+R_2)^{-1}+R_3^{-1})^{-1}[/tex]
[tex]R_{eq}=((R_1+R_2)^{-1}+R_3^{-1})^{-1}+R_5[/tex]
[tex]R_{eq}=((((R_1+R_2)^{-1}+R_3^{-1})^{-1}+R_5)^{-1}+R_4^{-1})^{-1}[/tex]
Then shove in 5 for R, and keep very close track of the inverses, and get a numerical answer.
I don't see that R5 is in series or in parallel with anything in this circuit... unless G is not connected to anything else but R4 and R5. The problem may have to make this explicit.
(And it's possible [especially with all of the resistors having the same value] that you get the correct numerical answer with the wrong physical reasoning.)
For part a:
start at point F. The current must be split through three parallel tracks in order to get to point H.
For part b:
If they don't go through R5, how else will R1, R2, and R3 be connected to point G?
mbrmbrg said:
For part a:
For part b:
I see now that I think the problem is not worded well... or the picture allows some ambiguity.
I would have preferred something like:
Consider five resistors arranged as follows (without any leads running out to the edge of the image). Now ask what is the equivalent resistance between some pair of nodes [assuming nothing is connected to the remaining node]. I think the leads running to the edge of the image suggest that something else may be connected. If so, then you'd have a three-terminal device and these methods won't work. See http://en.wikipedia.org/wiki/Analysis_of_resistive_circuits
  • · Replies 31 ·
