Calculating needed cable diameter
  • Thread starter Thread starter Liad
    Cable Diameter
The discussion focuses on calculating the appropriate cable diameter based on amperage or wattage requirements. Users recommend utilizing the National Electrical Code (NEC) tables or similar code books for accurate sizing. A specific resource, the InterfaceBus website, provides a comprehensive guide on copper wire sizes, which can aid in determining the correct diameter. This method ensures compliance with electrical standards and safety regulations.
  • Understanding of electrical concepts such as amperage and wattage
  • Familiarity with the National Electrical Code (NEC)
  • Knowledge of wire gauge standards, specifically American Wire Gauge (AWG)
  • Basic skills in using online resources for electrical calculations
  • Research the National Electrical Code (NEC) for wire sizing guidelines
  • Explore the InterfaceBus website for detailed information on copper wire sizes
  • Learn about voltage drop calculations for long cable runs
  • Investigate the impact of temperature and insulation type on wire sizing
Electrical engineers, electricians, and anyone involved in designing or installing electrical systems requiring precise cable sizing for safety and efficiency.
Liad
Hey!
How can I calculate what should be the cable diameter by the amper / watt?
Best Regards,
Liad.
By Amp. And it is probably easiest to just use the tables in the NEC or other code book (if you aren't American).
  • · Replies 72 ·
22K
