Calculators Why Is My TI-89 Titanium Giving Unexpected Results for Functions?
The user is experiencing issues with their TI-Titanium calculator, specifically with obtaining numerical results for square roots and trigonometric functions. When attempting to calculate the square root of 5, the output is the symbolic form rather than the decimal approximation. This issue is likely related to the calculator's settings, particularly the mode for displaying results. Additionally, when solving the equation tanθ=2/1, the user receives a complex output instead of the expected angle in degrees. Changing the settings to degrees did not resolve the issue. A suggested solution is to change the calculator's option for results from exact to approximate, which successfully provided the desired numerical answers. Proper syntax is also emphasized as crucial for accurate calculations on TI calculators.
brown.ty
Hello, I am new to the TI-Titanium and have run into a few rather simple obstacles that are keeping me from answering physics questions in the correct way.
First off, by typing:
\sqrt(5)
the answer comes out to:
=\sqrt(5)
as opposed to 2.2360...
(I believe this is a setting/mode issue)
Secondly, I have a simple trig function:
tanθ=2/1
to solve, I typed:
tan-1(2/1) as one would do and the result was:
(-90*(((tan-1(1/2)-pi)/90)-pi)/pi
Now this answer seems to be in radians, and so I changed the setting to degrees..still I get this same answer.
The actual textbook answer was:
θ=63.4°
Why is this happening?
If anyone could tell me what it is I have to do in order for my TI-89 to answer these problems in the way I'd like them to be answered I would greatly appreciate it!
Thanks in advance!
Computer science news on Phys.org
Try changing the option for results from exact to approximate and see if that works. TI calculators can be very picky when it comes to syntax so be careful about that too.
That worked! Thank you Skrambles!
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
16K
10K
