Physical equivalence of Lagrangian under addition of dF/dt
The discussion revolves around the physical invariance of Lagrangians, specifically addressing the question of how the Euler-Lagrange equations are affected by the addition of a term of the form dF/dt to the Lagrangian. The original poster is revisiting concepts from Analytical Mechanics and seeks to understand the implications of this addition on the equations governing motion.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the substitution of the modified Lagrangian into the Euler-Lagrange equations and discuss the necessary conditions for the additional terms to equate to zero. There is also a consideration of using the action principle as an alternative approach.
Some participants have provided guidance on the differentiation process and the application of the chain rule, while others are exploring different methods to arrive at the same conclusion. There is an acknowledgment of the complexity involved in the differentiation of the added term and its implications on the overall proof.
Participants note that the original poster is working through these problems independently, despite having graduated, and that the textbook being used does not cover the action principle until later, influencing the approach taken in the discussion.
Favicon
This isn't strictly a homework question as I've already graduated and now work as a web developer. However, I'm attempting to recover my ability to do physics (it's been a few months now) by working my way through the problems in Analytical Mechanics (Hand and Finch) in my free time and have got stuck on a question about physically invariant Lagrangians. I understand that the Lagrangian of a physical system is not unique because there are many Lagrangians for which the Euler-Lagrange equations reduce to the same thing.
The question I can't solve asks for a proof that the Euler-Lagrange (EL) equations are unchanged by the addition of [itex]dF/dt[/itex] to the Lagrangian, where [itex]F \equiv F(q_1, ..., q_2, t)[/itex].
Euler-Lagrange equations: [itex]\frac{d}{dt}\frac{∂L}{∂\dot{q_k}} - \frac{∂L}{∂q_k} = 0[/itex]
Change of Lagrangian [itex]L \rightarrow L' = L + \frac{dF}{dt}[/itex]
Chain rule: [itex]\frac{dF}{dt} = \sum\limits_k{\frac{∂F}{∂q_k}\frac{∂q_k}{∂t}}[/itex]
I guess the solution is to substitute the new Lagrangian, [itex]L'[/itex], into the EL equations and somehow show that it reduces to exactly the EL equations for [itex]L[/itex]. The substitution gives:
[itex]\frac{d}{dt}\frac{∂}{∂\dot{q_k}}\left(L + \frac{dF}{dt}\right) - \frac{∂}{∂q_k}\left(L + \frac{dF}{dt}\right) = 0[/itex]
This can be rewritten as:
[itex]\left(\frac{d}{dt}\frac{∂L}{∂\dot{q_k}} - \frac{∂L}{∂q_k}\right) + \left(\frac{d}{dt}\frac{∂}{∂\dot{q_k}}\frac{dF}{dt} - \frac{∂}{∂q_k}\frac{dF}{dt}\right) = 0[/itex]
where the first set of bracketed terms are just the left hand side of the EL equation in L. Therefore, I now need to show that the other bracketed terms equate to zero also. i.e.
[itex]\frac{d}{dt}\frac{∂}{∂\dot{q_k}}\frac{dF}{dt} - \frac{∂}{∂q_k}\frac{dF}{dt} = 0[/itex]
All I can think of to try next is apply the chain rule to the differentiation of [itex]F[/itex] and then hope that everything cancels nicely.
Applying the chain rule gives:
[itex]\frac{d}{dt}\frac{∂}{∂\dot{q_k}}\frac{∂F}{∂q_k} \frac{∂q_k}{∂t} + \frac{∂}{∂q_k}\frac{∂F}{∂q_k}\frac{∂q_k}{∂t} = 0[/itex]
So I guess my proof works if [itex]\frac{d}{dt}\frac{∂}{∂\dot{q_k}} = \frac{d}{dt}\frac{∂}{∂q_k/∂t}[/itex] is equivalent to [itex]\frac{∂}{∂q_k}[/itex]. Is this correct? I feel like you can't just cancel the [itex]dt[/itex] and [itex]∂t[/itex] like this, but I can't see how else this proof can be done.
Correctly: [tex]\frac{dF}{dt} = \sum\limits_k{\frac{∂F}{∂q_k}\frac{dq_k}{dt}}+ \frac {∂F}{∂t}[/tex],
that is
[tex]\frac{dF}{dt} = \sum\limits_k{\frac{∂F}{∂q_k}\dot q_k}+ \frac {∂F}{∂t}[/tex]
Correct.
Substitute equation [itex]\frac{dF}{dt} = \sum\limits_k{\frac{∂F}{∂q_k}\dot q_k}+ \frac {∂F}{∂t}[/itex] for dF/dt, derive it with respect of [itex]\dot q_k[/itex] and apply chain rule again when determining the time derivative.
ehild
You can do it without going all that dirty work by looking at the action
[itex]S=\int L dt = \int (L' + \frac{dF}{dt})dt[/itex]
That method seems much neater to me
Mod note: removed remaining steps.[/color]
Yes, the variation of F disappears between the endpoints of the path... That was as we learnt, but it works with the derivatives, too.
Indeed, I was aware of the action as the simpler way to prove it, but I wanted to do it with derivatives too as the book I'm working from doesn't discuss action until later on. Thought it made a good exercise in partial differentiation and chain rule, which it seems I needed! In fact I'm still struggling a little. Applying the chain rule gives me:
[itex] \frac{d}{dt}\frac{\partial}{\partial \dot{q_k}}\frac{dF}{dt} = \left(\frac{\partial^2 F}{\partial q_k^2} + \frac{\partial^3F}{\partial q_k \partial \dot{q_k}\partial q_k} + \frac{\partial^3F}{\partial q_k\partial \dot{q_k}\partial t}\right) \dot{q_k} + \frac{\partial^2F}{\partial t\partial q_k} + \frac{\partial^3 F}{\partial t\partial\dot{q_k}\partial q_k} + \frac{\partial^3F}{\partial t\partial\dot{q_k}\partial t}[/itex]
and
[itex] \frac{\partial}{\partial q_k}\frac{dF}{dt} = \frac{\partial}{\partial q_k}\left(\frac{\partial F}{\partial q_k}\dot{q_k} + \frac{\partial F}{\partial t}\right)[/itex]
Now, it seems to me that the only way this doesn't end with a lot of second and third order partial derivatives that don't cancel out is if I've got a sign wrong. For instance, if the chain rule had a minus [itex]\frac{\partial F}{\partial t}[/itex] at the end instead of plus, then I think everything would cancel out perfectly with each of the above becoming equal to zero, as required. But I don't think the chain rule should have a negative term like that.
Have I missed something?
Have you read my post #2?
First determine he derivative of dF/dt with respect to one of the velocity components, [itex]\dot q_j[/itex]
As F itself does not depend on the velocities,
[tex]\frac{\partial}{\partial \dot q_j}\frac{dF}{dt}=\frac{∂F}{∂q_j}[/tex]
Then take the time derivative of [itex]\frac{\partial}{\partial \dot q_j}\frac{dF}{dt}=\frac{∂F}{∂q_j}[/itex]:
[tex]\frac{d}{dt} ( \frac{∂F}{∂q_j} )[/tex]
and you have to subtract [itex]\frac{∂}{∂q_j}\frac{dF}{dt}[/itex] at the end.
ehild
Ah ha, it was the [itex]\frac{\partial }{\partial \dot{q_j}}\frac{dF}{dt} = \frac{\partial F}{\partial q_j}[/itex] that I missed. That got rid of all the 3rd order derivatives, leaving only 2nd order one's which all cancel each other out in the end. Thanks very much for the help ehild!
It was a great battle that ended well... :smile:
ehild
  • · Replies 16 ·
