Switching time of a mechanical switch - capacitive model
The discussion revolves around calculating the switching time of a mechanical switch, specifically a capacitive switch used in RF MEMS applications. Participants explore the dynamics of the switch, including the effects of electrostatic forces, spring forces, and damping due to air. The context is technical and relates to research in nano-scale structures.
  • Homework-related
  • Sandeep outlines the problem of finding the switching time of a mechanical switch with a voltage applied to an actuation pad and a movable beam with a spring constant K.
  • Some participants inquire about the context of the question, including whether it is for a school project and the choice of a capacitive switch over an inductive one.
  • Sandeep explains that the switch is part of a research project in RF MEMS, aimed at achieving higher switching speeds with lower capacitance compared to semiconductor switches.
  • Sandeep presents the forces acting on the beam: electrostatic force, spring force, and damping force, and describes the equations derived from conservation of energy.
  • There is a challenge in integrating the damping term into the equations, and Sandeep expresses uncertainty about how to proceed with the integration.
The discussion remains unresolved, with participants providing insights and questions but no consensus on the integration method or the overall approach to the problem.
Participants have not fully explored the implications of neglecting damping in the calculations, and there are unresolved mathematical steps regarding the integration of the damping term.
msandeep92
Hi,
I am trying to solve a problem, where i need to find the switching time of a mechanical switch.
A voltage of V is applied to an acutation pad, and the movable beam is assumed to have a spring constant of K.
I have attached the photo for better clarity.
Please help me out. Consider the damping of the switch due to air also.
Thanks,
Sandeep.
msandeep92 said:
Hi,
Thanks,
Sandeep.
Welcome to the PF.
What is the context of your question? Is this for a school research project? Why are you using a capacitive switch instead of inductive? Is this for a nano-scale structure? Why would you still have air in the assembly? What have you done so far on this problem?
Yes. This is a part of my research project.
This is a nano scale structure. This is a capactive switch being used in RF MEMS - one of the latest emerging fields which is hoped to replace the semiconductor switches for RF applications. Semiconductor switches have very high capacticances turning up at high frequencies. So, we use these switches as a replacement, which provide lower capacitance and hence higher isolation.
We are deivcing a new model of the switch for higher switching speed. So, in this regard i need this calculation.
What i have done so far on the beam is:
Electrostatic force Fe = εA(V^2 )/(2*(d-x)^2);
Froce due to spiring Fk = -K*x;
Force due to damping Fd = - b*(dx/dt)
Using conservation of energy:
.5*m*(v^2) = ∫Fdx
F = Fe + Fk + Fd
Neglect the damping as of now.
If i go on integrating Fe and Fd, i get:
dx/dt = √[(εA(V^2)x/m(d-x)d) - k(x^2)/2] = p
From here, i get time by t = ∫(dx/p).
I am struck in this integration, Please help me.
I am not able to understand how to integrate the damping term also.
Thanks,
Sandeep.
You can see this paper(attached) for better understanding.
  • · Replies 24 ·
