Calculating Heat Needed to Melt Metal
  • Thread starter Thread starter Weave
    Heat Metal
The discussion revolves around calculating the heat required to melt a metal, considering its mass, initial temperature, heat capacity, and melting point. Participants are exploring the concepts of heat transfer and phase changes in the context of thermodynamics.
  • Mixed
  • Participants discuss the formula for calculating heat, with initial attempts focusing on the energy needed to raise the temperature to the melting point. There is a shift towards considering the latent heat required for the phase change from solid to liquid.
Some participants have offered clarifications regarding the need to account for both the temperature change and the phase change in the calculations. There is an ongoing exploration of the implications of these factors, with no clear consensus reached on the final approach.
There is a recognition that the problem may not be fully answerable without additional information, specifically the latent heat value. Participants are questioning the assumptions made in their calculations.
Weave
Ok this one is easy I just want to make sure:
A metal of mass [tex]M[/tex] is in a smelter at temperature [tex]T_{o}[/tex].
How much heat does it take to melt the metal. Given: heat capacity, melting point [tex]T_{m}[/tex]
[tex]Q=Mc\Delta T[/tex]
So it would be simply
[tex]Q=Mc(T_{m}-T_{o})[/tex]
Right?
That's just the energy required to heat the metal up to the melting point, what about the actual phase change (i.e. latent heat)?
so [tex]\frac{Q}{M}=L[/tex] Q being the previous answer from [tex]Q=Mc\Delta T[/tex]
it should be [tex]Q=Mc\Delta T + ML[/tex] if you melt solid to liquid
[tex]Q=Mc\Delta T[/tex] (unchange state)
[tex]Q=ML[/tex] (change state)
So I am incorrect?
Q isn't necessarily that from the previous answer.
so..what I am I looking for?
I'd be tempted to say that the question isn't answerable unless your given L; but I'm willing to learn...
