What is the phase difference between the motions of two points on the wave
The discussion revolves around determining the phase difference between the motions of two points on a wave, specifically when the points are 0.17 cm apart. The wave has a frequency of 500 Hz and a speed of 340 m/s.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between distance and phase difference, referencing the wavelength and its implications for points separated by different distances. There is an exploration of how to calculate the phase difference based on known values.
The discussion includes various interpretations of the phase difference based on the distance between points. Some participants suggest calculations while others clarify the relationship between distance and phase difference, indicating a productive exploration of the topic.
There is a mix-up in units (cm vs. m) that participants address, and the original poster is encouraged to define terms in their equations. The forum policy against providing outright answers is acknowledged in the conversation.
looi76
[SOLVED] What is the phase difference between the motions of two points on the wave..
The frequency of a certain wave is [tex]500Hz[/tex] and its speed is [tex]340ms^{-1}[/tex].What is the phase difference between the motions of two points on the wave [tex]0.17cm[/tex] apart?
[tex]x = \frac{d\lambda}{a}[/tex]
[tex]v = f\lambda[/tex]
[tex]f = 500Hz \ \ \ v = 340ms^{-1} \ \ \ a = 0.17 \times 10^{-2} cm[/tex]
[tex]\lambda = \frac{v}{f} = \frac{340}{500} = 0.68m[/tex]
What should I do next?
Two points 0.68cm apart will be out of phase by 360 degrees.
Two points [itex]\lambda[/itex] apart will be out of phase by 360 deg.
Regards,
Bill
In this case that is 0.68m. Damn I just realized I said cm, but you know what I mean. :-p
So, the answer is = 0.68m by 360° ?
No, I won't be. You know the phase difference between points 0.68m apart is 360°, the question asks the phase difference for 0.17m, which happens to be a quarter the quantity of which we do know the phase difference for. Just one more step =]
Define the terms in your first relevant equation - one of those terms should be what you solve for to get the answer.
BTW - check what you wrote for "a" (cm?).
Regards,
Bill
As GibZ alluded to, I was trying to coax you toward the right answer not just give you the answer outright (since that would be against forum policy).
[tex]0.68m = 360^o[/tex]
[tex]0.17m = x[/tex]
[tex]x = \frac{0.17 \times 360}{0.68}[/tex]
[tex]x = 90^o[/tex]
So, the phase difference is [tex]90^o[/tex] ?
Thats correct.
