Which Particle Physics Textbook is Better for a Master's Degree Student?
The discussion centers on selecting an experimental textbook for a master's degree in particle physics, specifically comparing "Introduction to High Energy Physics" by Perkins and "Particle Physics" by B.R. Martin & G. Shaw. The latter is noted for being comprehensive and suitable for self-study, with solutions provided for problems. However, a strong recommendation is made for Griffiths' "Introduction to Elementary Particles," praised for its clear explanations and inclusion of basic Quantum Field Theory, making it slightly more advanced but beneficial for understanding key concepts. The consensus suggests avoiding Perkins due to its perceived difficulty in learning. Additionally, Martin's book is highlighted for its up-to-date content.
welatiger
Hi all;
I will work master's degree in particle physics and I want an experimental textbook for particle physics, and i have two choices
is "Introduction to high energy physics" by Perkins
or "particle physics" by B.R. Martin & G. Shaw
Can you advise me
I haven't used Perkins myself so I can't say anything about it, but Martin&Shaw I've used. It is quite nice and often comprehensive and contains most of what you need on an introductory level (basic QM is probably all you will need). It also has solutions to all problems which is nice if you use it for self study.
However, I would instead recommend Griffiths "Introduction to Elementary Particles". It is better than the other in my opinion, better explanations of the concepts in the comprehensive style of Griffiths. It is a bit more advanced than the previous two (don't know about Perkins as I said) since it also introduces a basic form of Quantum Field Theory to be able to calculate cross sections, but it covers the same concepts (at least as Martin&Shaw).
thank you so much
i think that Martin's book advantage is it is up to date
The book is fascinating. If your education includes a typical math degree curriculum, with Lebesgue integration, functional analysis, etc, it teaches QFT with only a passing acquaintance of ordinary QM you would get at HS. However, I would read Lenny Susskind's book on QM first. Purchased a copy straight away, but it will not arrive until the end of December; however, Scribd has a PDF I am now studying. The first part introduces distribution theory (and other related concepts), which...
