| New Reply |
obstacles to fusion energy for civilian purposes |
Share Thread |
| Jan28-12, 10:29 PM | #1 |
Does all it require to create fusion energy is to heat something up to 8000 C? Is that in principle all that it requires? Does it require any other fundamental tricks?
| Jan28-12, 11:14 PM | #2 |
you're creating a plasma at 8000C and you'll need a magnetic bottle to contain it that's one of the problems as they interact and the plasma breaks out of the bottle.
The other way is by zapping a pellet of fusible material dropped into a sphere by lasers from all directions causing a fusion explosion. The debris clouds up the glass that the lasers shoot thru decreasing efficiency. |
| Jan29-12, 08:40 AM | #3 |
Getting fusion for a moment is pretty easy, researchers were achieving it routinely as early as the 1950s.
Getting sustained fusion at a high enough level to allow useful energy to be extracted is the problem. We have not yet been able to build a fusion reactor that merely breaks even energetically, nor have we solved the thorny task of engineering a reactor that will be able to sustain fusion reactions for decades. Our current designs, the ITER project in Europe and the US laser implosion driven approach mentioned by jedishrfu, are both huge, stadium sized devices that maybe hopefully will generate some excess energy once they work. Neither would be anywhere near ready for prime time as an energy source. |
| Jan29-12, 10:31 AM | #4 |
Admin
obstacles to fusion energy for civilian purposesTwo approaches are inertial confinement whereby a pellet of frozen deuterium or deteurim+tritim is blasted with lasers such that the ablation of the outer layers compresses the heated pellet to the millions of K and high density required for fusion, and magnetic confinement whereby a heated plasma is magetically confined long enough to have a sufficient amount of fusion energy production to exceed the energy input into the plasma. The problem with magnetic confinement is that the pressures, which are proportional to temperature and particle density, are limited by magnetic field strength, which is an inherent physical limitation of the superconductors and the structure. The d+t reaction is the easist to obtain, but it is handicapped by the fact the 80% of the fusion energy is taken by the 14.1 MeV neutrons, and only 3.5 MeV goes to the alpha particle. More attractive reactions, e.g., d + He3, which is aneutronic, are handicapped by the requirement for higher temperatures, hence lower particle densities, and in the case of d+He3, He3 is rather rare. Other challenges are heating the plasma efficiently and minimizing the energy losses due to cyclotron radiation, brehmsstrahlung radiation, recombination, and leakage of neutrals, as well as degradation of strucutural materials under high temperature irradiation. |
| Jan30-12, 01:34 PM | #5 |
| Apr8-12, 12:14 PM | #6 |
It should be easy to create the necessary fusion temperature because there is no theoretical limit (AFIK) to how much laser energy can be put into a small space.
So it is only a matter of concentrating enough laser beams onto one spot. Cannot understand our delay in this one. It should be possible even with a small laser in a thin enough beam. |
| Apr8-12, 12:38 PM | #7 |
Admin
Then there is the matter of repetitively hitting small capsules of DT at a rate that produces far more energy than is recycled into the laser system. It is not trivial. |
| Apr8-12, 12:53 PM | #8 |
Oh, so it looks like practical solution are difficult. Do you think there will be an ingenious easy answer or is it a matter of continuing overcoming hurdles?
| Apr8-12, 01:04 PM | #9 |
Admin
| Apr11-12, 03:40 PM | #10 |
Is magnetized target fusion a viable option for a commercial reactor? I was reading about the work being done by General Fusion in B.C. Canada: http://www.generalfusion.com/index.html
| Apr24-12, 07:08 AM | #11 |
Here are a few obstacles that laser ICF power plants still need to overcome:
| New Reply |
Similar discussions for: obstacles to fusion energy for civilian purposes
| Thread | Forum | Replies | ||
| Recent EE grad with civilian job considering AFR or ANG | Career Guidance | 11 | ||
| Support India's Civilian Nuclear Program ? | Current Events | 6 | ||
| Acceptable civilian casualties | Current Events | 143 | ||
| Iraqi group claims over 37,000 civilian toll | Current Events | 81 | ||
| American Civilian Beheaded in Iraq | Current Events | 127 | ||
