| New Reply |
What do vector operators mean? |
Share Thread | Thread Tools |
| Aug17-12, 07:47 PM | #1 |
My QM book introduces operators like the momentum operator [itex]\hat{\mathbf{p}}[/itex] which act on their eigenstates to produce new states like [itex]\hat{\mathbf{p}}|\mathbf{p}\rangle = \mathbf{p}|\mathbf{p}\rangle[/itex]. But how can we interpret a state like that? How is multiplication between a Euclidean vector and a vector in Hilbert space defined?
| Aug17-12, 07:56 PM | #2 |
Recognitions:
It should be [itex]\hat{\mathbf{p}}|\mathbf{p}\rangle = p|\mathbf{p}\rangle[/itex], where the formula is the definition of an eigenstate [itex]|\mathbf{p}\rangle[/itex] of the operator [itex]\hat{\mathbf{p}}[/itex] . An eigenstate of an operator is a vector which is not rotated, but only changed in length by the operator (multiplied by a scalar).
| Aug17-12, 08:06 PM | #3 |
Mentor
##\left|\mathbf p\rangle\right.## denotes an eigenstate of all three components of ##\hat{\mathbf p}=\big(\hat{p}_1,\hat{p}_2,\hat{p}_3\big)##. So
$$\hat{\mathbf p}\left|\mathbf p\rangle\right.=\mathbf p\left|\mathbf p\rangle\right.$$ should be interpreted as For all ##i\in\{1,2,3\},## we have |
| Aug17-12, 09:33 PM | #4 |
| Aug17-12, 09:45 PM | #5 |
Recognitions:
| Aug17-12, 09:52 PM | #6 |
Thanks everyone, especially Fredrik.
| Aug17-12, 10:12 PM | #7 |
| Aug18-12, 10:03 AM | #8 |
Mentor
The relevant coordinate systems are in bijective correspondence with the members of SO(3), so the easiest way to define the association is to first assign the triple ##\mathbf p## to the coordinate system we had in mind when we wrote $$\hat{\mathbf p}\left|\mathbf p\rangle\right.=\mathbf p\left|\mathbf p\rangle\right. ,$$ and then assign the triple ##R\mathbf{p}## to the coordinate system such that a change of coordinates to this new system is given by R. But now there's nothing to prove. What we did is the same thing as saying that we're dealing with "the tensor that has components ##\mathbf{p}## in the coordinate system we're using now", so we have assumed what you wanted to prove. Another way to do the association is to first assign a triple of momentum operators to each coordinate system: Consider an arbitrary coordinate system (in addition to the one in which we are already using the notation ##\hat{p}_i## for our momentum operators. Let R be the function (member of SO(3)) that changes coordinates to the new system. Then we associate the operators ##\hat{p}_i'=U(R)\hat{p}_iU(R)^{-1}=R_{ij}\hat{p}_j## with the new coordinate system. Now we can associate a triple of real numbers with the new coordinate system, by saying that ##p_i'## denotes the eigenvalue of ##\hat{p}'## associated with the eigenstate ##\left|\mathbf p\rangle\right.##. Then we have $$p_i'=\langle\mathbf{p}|\hat{p}_i' |\mathbf{p}\rangle =R_{ij}\langle\mathbf{p}|\hat{p}_i |\mathbf{p}\rangle =R_{ij}p_j=(R\mathbf{p})_i,$$ as desired. |
| Aug18-12, 10:25 AM | #9 |
Projection operation. You have a state vector in momentum space. The eigenstates form a basis for the momentum vector space. The momentum operator takes the state vector and projects it onto the basis vectors. Right?
| Aug18-12, 11:18 PM | #10 |
Mentor
Momentum space? Momentum vector space? If ##|\psi\rangle## is the state vector, then the function ##\mathbf{p}\mapsto\langle\mathbf{p}|\psi\rangle## can be thought of as a momentum-space wavefunction. Is that what you have in mind? |
| Aug19-12, 12:37 PM | #11 |
| Aug20-12, 07:24 PM | #12 |
Recognitions:
| Aug21-12, 01:26 AM | #13 |
| New Reply |
| Thread Tools | |
Similar Threads for: What do vector operators mean?
| Thread | Forum | Replies | ||
| What are vector/tensors operators in QM or in general any vector space | Quantum Physics | 3 | ||
| Commutators of vector operators | Differential Equations | 4 | ||
| Properties of Hermitian operators in complex vector spaces | Advanced Physics Homework | 3 | ||
| Need a lot of help with vector fields/vector operators | Calculus & Beyond Homework | 3 | ||
| vector field operators | Introductory Physics Homework | 2 | ||
