| New Reply |
Deduce the rate law expression |
Share Thread | Thread Tools |
| Sep17-12, 08:29 AM | #1 |
1. The problem statement, all variables and given/known data
The inversion of cane sugar proceeds with a constant half life of 500 minute at pH=5 for any concentration of sugar. When pH is changed to 4, the half life becomes 50 minutes. Deduce the rate law expression for inversion of sugar. 2. Relevant equations [itex]t_{1/2}*a^{n-1}[/itex] is constant for reaction of any order 3. The attempt at a solution Since pH=5 Therefore, [itex][H^{+}]=10^{-5}[/itex] (Initial Concentration) Similarly Final [itex][H^{+}]=10^{-4}[/itex] Using first equation I have 500*[itex](10^{-5})^{n-1}[/itex]=50*[itex](10^{-4})^{n-1}[/itex] 10=[itex]10^{n-1}[/itex] n=2 So it must be second order wrt [itex][H^{+}][/itex] Since the rate does not depend of sugar so it must be zero order wrt sugar Therefore the rate law expression should be Rate=k[Ester][itex][H^{+}]^{2}[/itex] But the answer in my book says Rate=k[Ester][itex][H^{+}][/itex] Whats wrong? |
| Sep18-12, 07:58 AM | #2 |
What is wrong is that the equation you have quoted relates to a changing half-life as a reaction proceeds. In this case you need a different approach because you are looking at initial rates of two separate reaction mixtures. The half-life does not change as the reaction proceeds. That in itself might tell you something.
What you can do, having decided that a(H+) is the important factor, is test how the initial half life would change if the reaction were first order, second order, zero order, minus 1 order in that activity. When you increase the activity by a factor of 10, what happens to the half-life? What is therefore happening to the rate? Is the rate proportional to the activity? to the square of the activity? invariant? inversely proportional to the activity? |
| Sep19-12, 02:48 AM | #3 |
| Sep19-12, 03:18 AM | #4 |
The pH4 and pH5 solutions do not count as initial and final concentrations. Both solutions are buffered, and in both cases the pH does not change as the reaction proceeds. You need some other way of getting the order with respect to the activity of H+.
There are two different reaction setups, and for each of them the pH represents both the initial and the final concentration. You simply cannot use the equation you have quoted, but there is another very simple way to get the reaction order. |
| Sep19-12, 08:38 AM | #5 |
| New Reply |
| Thread Tools | |
Similar Threads for: Deduce the rate law expression
| Thread | Forum | Replies | ||
| Derive an expression for the rate of interactions in a fixed target experiment... | Advanced Physics Homework | 1 | ||
| expression of the rate dV/dt | Introductory Physics Homework | 1 | ||
| Expression for height of water as a function of time given flow rate in and out | Calculus & Beyond Homework | 1 | ||
| how to deduce this formula | Advanced Physics Homework | 9 | ||
| How to deduce this conclusion | Introductory Physics Homework | 0 | ||
