| New Reply |
The Equation for Volumetric Flow Rate? |
Share Thread | Thread Tools |
| Nov27-12, 03:44 AM | #1 |
I'm not sure how to clearly express my query, so I'll round up the gist of it. I understand that this is an entry level question.
I was told that, in order to calculate Volume Flow Rate (VFR), I would use these equations: * Q = Velocity * Area [EQUATION 1] * Q = Volume / Time [EQUATION 2] Units: m^3 / s Questions: ^Do I use both equations? Are they both deemed correct or only one and which one? ^Can you give an example problem or scenario in which I would use the appropriate equation? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Nov27-12, 04:55 AM | #2 |
Example: You have a pipe with a diameter of 400mm. Water flows through the pipe at a velocity of 1 m/s. Determine how many liters you would have collected in a minute?
Use your equation as you mentioned and come up with a solution, don't et sidetracked by the units, do the first principals correctly... |
| Nov27-12, 05:33 AM | #3 |
@WillemBouwer Correct?
Prompt: A pipe has a diameter of .4 meters. Water flows through the pipe at 1 m/s. Determine how many liters (water) you would have collected in a minute? Radius: .2 meters (m) Vinitial: 1 m/s Volume: ? Time: 60 seconds Q = V * A Q = 1 * (∏(.22)) Q = 0 .1256637061 m3/s --> Q = V / T .1256637061 = V / 60 Volume = 7.539822369 m3 or 7.539822369 * 1000 = 7,539.822369 L 1 m3 = 1000 Liters (L) |
| Nov27-12, 05:41 AM | #4 |
There you go... Using the equation right...
The second equation is just an explaining of the units or terminology, Volume flowrate is exactly that, m^3/s, volume over time. But the first equation is the most commonly used. However when you get a question, make sure to answer the question as asked with units, always remember your units... But you understand the principal! Cool beans... So, how many liters per minute? |
| Nov27-12, 05:50 AM | #5 |
It should be on there.
7,539.822369 L ? Thank you very much Mr. Bouwer. (: |
| Nov27-12, 06:00 AM | #6 |
No problem. I see it shows now, didn't the previous one, haha. good job though, correct answer...
| New Reply |
| Thread Tools | |
Similar Threads for: The Equation for Volumetric Flow Rate?
| Thread | Forum | Replies | ||
| Volumetric flow rate - Help needed | Mechanical Engineering | 0 | ||
| At what volumetric flow rate will air fill a space vacuum at Earth's STP? | General Physics | 19 | ||
| Volumetric flow rate (simple???) | Engineering, Comp Sci, & Technology Homework | 1 | ||
| volumetric flow rate | Engineering Systems & Design | 7 | ||
